Evosport | 390mm Brake Rotor Upgrade for E55 AMG
Old Oct 25, 2012 | 07:53 PM
streetspeeder's Avatar
2006 E55 AMG
das a dam big pic bro!
Old Oct 26, 2012 | 12:20 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
$1900 waste of money....... what's the real improvement ? lighter then what ? how much is the set include rear ? $3.5k ? I hope evosport know the market price of AMG.
Old Oct 26, 2012 | 06:38 AM
marc.l's Avatar
2003 E55 estate
I agree wildwood and all the after market wheel manufactures use alloy for bells . But I when I was looking for new bells the likes of brabus , and few others strongly recommended not to use alloy due to the weight of the car and the load it puts on the mounting points of the rotor to bell.
Old Oct 26, 2012 | 10:14 AM
2006 E55 AMG
Yes that make sense...
Here is some Braking Tidbits...so yes the larger Rotor does increase the effective radius of the clamping force by a whopping 6.6% (14" to 15") or so?...with all else equal Right?
Same Pads, same calipers, same car!...is it worth $1900 to to you?
Old Oct 28, 2012 | 12:56 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Don't think caliper weight nearly as important as disc weight... the rotational mass amplifies the gyroscopic forces big time. A static caliper is unwanted unsprung mass but it isn't spinning.
I think they could get this setup right with oversized pads... otherwise I don't get it ... oh and yes it needs to be about 900$ cheaper
Old Oct 28, 2012 | 01:58 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Even with over sized pads the rotors and pads will wear out uneven over time due to the pistons not able to applied even pressure on the pads.
Old Oct 28, 2012 | 03:16 PM
  #32
cwmateiuc's Avatar
2006 E55 AMG
$1,900 for two front rotors? They do realize that E55's came out in 2003 and whoever is willing to pay that is most likely drunk at the time of purchase?
Old Oct 29, 2012 | 06:25 AM
  #33
komp55's Avatar
ML550
Brembo doesn't know how to engineer large multi-piece brake discs and that's why they use lightweight hats on their GT kits.
Old Oct 29, 2012 | 04:20 PM
  #34
marc.l's Avatar
2003 E55 estate
I'm only talking from exsperiance after talking to quite a few manufactures , alcon included . Main reason was given as the weight of the car and would only produce the bells from a cast or from stainless steel . Tbh I always assumed the brabus bells would be alloy and was surprised to see they were machined cast iron .
Marc
Old Oct 30, 2012 | 10:09 AM
  #35
2006 E55 AMG
I think its fair to say the 15.4" Rotors are "Cosmetic"...and I look good already!...
Old Dec 19, 2012 | 06:34 PM
  #36
KCE55's Avatar
2006 E55 AMG
Hello All,
I am new to this site, i have a 2006 E55 that will need front rotors soon. The dealer said about 3,500 to replace. Is there anyone that sells aftermarket rotors for these cars?
Thanks,
Matt
Old Dec 19, 2012 | 06:49 PM
  #37
sales @ evosport's Avatar
Mercedes-Benz AMG
Originally Posted by KCE55
Hello All,
Thanks,
Matt
Matt: Feel free to contact us. We have 2-piece rotors in stock and ready to ship for your car. Happy Holidays!
Old Dec 19, 2012 | 07:30 PM
  #38
FASN8N's Avatar
CTSV/6sp Grocery Getter
Hello All,
Thanks,
Matt
Your dealer is either smoking crack, ripping you off really badly, or confusing your E55 with an E63 (and still making an absurd profit)
Parts.com has OEM front rotors for $104.40 each
The E63 rotors are listed on parts.com for $756 each
Old Dec 20, 2012 | 08:04 PM
  #39
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
The new 390mm look nice!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
