17" C-Class wheels for drag wheels?
Old Oct 23, 2012 | 05:14 PM
Iceman's Avatar
E55
I was wondering if anyone knows if 17" C Class wheels will fit the rear of our cars? I have found a set with drag radials and I am not sure if they will fit correctly. If they will not, does anyone know what spacer would be required to use them? I would prefer to use the 16" CLK wheels but these wheels are local and already have the drag radials mounted (275/40/17 Mickey Thompsons). Any help would be appreciated.
Old Oct 24, 2012 | 10:37 AM
Iceman's Avatar
E55
Bueller....Bueller. Any help?
Old Oct 24, 2012 | 05:02 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
17 by what? 17 x 8.5? What's the offset?
Old Oct 24, 2012 | 05:37 PM
Iceman's Avatar
E55
It appears they are 17x8.5", et35. They are the seven spoke wheel that came on the C-Class. They are not the ultimate setup but would at least work for the track if they will fit. Thanks for the help.
Old Oct 24, 2012 | 05:57 PM
My setup I used to get all of my 11sec runs were with the MB OEM wheels 17x8.5 with 275/40/17 MT's @ 20psi
Old Oct 24, 2012 | 07:50 PM
Iceman's Avatar
E55
Do you think these wheels will fit? I would prefer to go with the super light CLK wheels or even a CCW drag setup but I am trying to be frugal with this car.
Old Oct 24, 2012 | 07:59 PM
Do you have any mods or are you stock? Either way they will fit
Old Oct 25, 2012 | 11:08 AM
Iceman's Avatar
E55
My car has a few mods:
Kleemann 168 pulley
PLM shorty headers
PLM heat exchanger
Johnson pump
Dyno-Comp tune
Primary cat delete with test pipes welded in. O2 sensors coded by Kleemann to show ready (no CEL)
I have a co-worker with a 2010 CTS-V with headers and a pulley that has told me how he will destroy me. I have several other "fast" cars and have spent plenty of time at the track. What I plan to do is get to the track early, make sure my car is thoroughly cooled down, run 100 octane gas, and bolt on some good tires. His car ran 12.0 at 122 earlier this year....I know he has a horsepower advantage but I feel that if I am prepared I should win.
Old Oct 25, 2012 | 01:12 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
If you have a proper drag set up, you can certainly do better than a 12.0. You have a mid 11s car no doubt.
Old Oct 25, 2012 | 06:20 PM
+1 what he said ^^^^^^^
Old Oct 25, 2012 | 07:39 PM
skratch77's Avatar
2005 E55
I have 2 clk 16in light weight wheel boxed up ready to ship if your interested.I have 15mm spacers and can drill the holes for you also.
pm me if youre interested
