Jerry's a beast, Eurocharged is where it's at, and gear swaps are doable!
Old 12-05-2012, 10:01 AM
  #76
chawkins2001's Avatar
2006 E55 AMG
I picked up some 3.06's for my sled, cant wait to get it in there. Cant beat $100 shipped on the SRT8 ring and pinion gear either
Old 12-05-2012, 10:29 AM
  #77
GT-ER's Avatar
2005 E55 AMG
Holy crap, how did you do that? LOL
Old 12-05-2012, 10:48 AM
  #78
2006 E55 AMG
Going onto the Chrysler 300C SRT8 forums or you can get a complete diff with the gear in it off ebay or knowing a couple folks
http://www.ebay.com/itm/300442549149...84.m1423.l2649
Old 12-05-2012, 11:01 AM
  #79
underdogg's Avatar
2006 cls55
Will the whole unit work or just the gear?
Old 12-05-2012, 11:22 AM
  #80
GT-ER's Avatar
2005 E55 AMG
Will the entire diff swap in? That would be easier.
Old 12-05-2012, 12:10 PM
  #81
blackbenzz's Avatar
haters crazy
The mounting points are different. I had to have custom mounts and modify an E55 rear cover to fit it to a clk but clk is different than e.
Old 12-05-2012, 01:46 PM
  #82
Former Vendor of MBWorld
BI-Performance's Avatar
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Still a hell of a deal if that is all you have to do, I am also finding out for you guys if the SRT8 diffs came with an LSD from the factory.
Old 12-05-2012, 02:09 PM
  #83
blackbenzz's Avatar
haters crazy
The m215 did not but the newer 226 did but will be even more difficult to fit but also allows for even shorter gears than the m215 options
Old 12-05-2012, 02:29 PM
  #84
ProjectCamaro's Avatar
Pewter W211
With American sports cars this is one of the first modifications people do. Without much money you make your car much quicker without having to touch the engine. It's really a great modification.
Old 12-05-2012, 02:30 PM
  #85
Yip, just heard that the earlier SRT8's did not have LSD's in them, but the later year SRT8 Challangers do.
Old 12-05-2012, 02:41 PM
  #86
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Ahmad, when you say fit you mean the housing right. I'm wondering if the LSD and gears are the same internally and would fit into our existing housings. From what I recall, the SRT's use the same Quaife as the Benz for example. Maybe I have my facts wrong but was wondering.
Old 12-06-2012, 04:07 AM
  #87
blackbenzz's Avatar
haters crazy
Yes i was just referring to installing the complete diff, housing and all. I would think the internals are the same but i haven't personally compared since my clk came with a smaller 210 diff. I had to respline my hubs as well for bigger axles but you guys don't have to worry about that
Old 12-06-2012, 09:13 AM
  #88
whipplem104's Avatar
1990 300ce supercharged and intercooled
Chyrsler switched to using a Getrag differential that has a 226mm ring gear and comes with lsd. Nothing inside can be swapped. The housing is very different than the E class also. The E, CLS and Sl have a different housing than most other Mercedes. You guys will have to swap the gears out of the housing on the SRT-8 differential.
Old 12-06-2012, 09:59 AM
  #89
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
I made the switch,, from 307 to 327,, Jerry sent me a tcm, removed the diff with the 307,installed a diff. with 327 in it installed the tcm. this was done last Friday,,, Sunday we go to the track,,, the only thing so far is the shift from 2 to 3 is not what i want,, the red line was moved up to 6400. jim
Old 12-06-2012, 10:20 AM
  #90
blackbenzz's Avatar
haters crazy
+1
Nice Hopefully you see some gains. What's wrong with the 2-3 shift?Good luck at the track. I'm hoping the switch to 3.07 helps me some but i won't know until next year and will have a different setup then anyway
Old 12-06-2012, 10:54 AM
  #91
2006 E55 AMG
What size tire are you running and what are your 1-5 gear ratios? The diff you installed does not have the LSD in it?
Old 12-06-2012, 11:34 AM
  #92
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
What are your rpms at 70 mph now? Nice job on the gears and getting them lined out.
I honestly dont see how it would hurt performance at all. That car must pull so hard mang I would opt for 3.23 gear based on what suites my combo best. I am thinking that coupled with a 3000 stall would be viscious out the hole.
That would be the combo for me as well. I am half way there already
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 12-06-2012, 11:54 AM
  #93
blackbenzz's Avatar
haters crazy
Have you run your car yet? Didn't make it to MIR
Old 12-06-2012, 02:32 PM
  #94
amx1397's Avatar
tires MT 26 x10.5-16 this is the dot slick (not radial)
the 1 - 5 gears I don't know it is a SL55 engine and transmission,because the srt6 and the sl55 both use 307 gear i had to change nothing. I also have a wavetrac in the 307 diff.
now with the Diff.(out of a limited crossfire) 327 gear, i have the tuned tcm & a wavetrac posi unit in the car.
the 2nd to 3rd shift is not as hard as i want it ,if fact it feels like it is slipping,,, but the log shows no rpm increase.
My 307 diff. went to untrax for R&D as my unit was used as a test unit and was the prototype for the wavetrac for the crossfire. jim
Why don't you come on down for this Sunday's track rental ,,streetcardrags.com
Old 12-06-2012, 03:07 PM
  #95
blackbenzz's Avatar
haters crazy
I believe the SL55 uses 2.82 gears. Trans geared same as ours
Old 12-06-2012, 04:15 PM
  #96
amx1397's Avatar
just checked it and at 70mph my RPM was 2450
here is a pic of my log testing to 70 mph
1 eng temp 190
2 car's speed 70.mph
3 Iat's 57 degrees
6 engine RPM 2450
outside temp 81
Old 12-06-2012, 04:22 PM
  #97
2006 E55 AMG
cant wait for your track results jim. is this the only mod you have changed since your last visit? you got a killer chiller on that whip?
Old 12-06-2012, 04:23 PM
  #98
amx1397's Avatar
could not get the pic to upload so try this the was a 12 mile trip to the express way to test the 70 mph so with the inlarge buttom you will see the speed car temp MPH spark everything my loger logs as i drive along jim
http://s264.beta.photobucket.com/use..._0421.jpg.html
Old 12-06-2012, 04:41 PM
  #99
amx1397's Avatar
yes KC on it and NO,,,none, NO ,heat exchangers,,, i have 3 runs with the KC but not enough freon in the system to cool the IAT.s i had to use Ice,, then ran 11.22 @ 126 ,,when KC is installed you need to bring your low side of the AC to 38 to 40 the normal is 30 to 34... jim
Old 12-06-2012, 04:57 PM
  #100
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Your car did well with iats with the 3 heat exchangers you ran before so it will be interesting to hear your thoughts on the killer chiller. Also can't wait to see what your gear change does.
Quick Reply: Jerry's a beast, Eurocharged is where it's at, and gear swaps are doable!
