Vid of my 1.49 60ft @ MIR
Yes it is, thank you!
Thank you!
Big thanks brotha!
Thank you sir!
Thank you very much
thanks
thanks
Thanks brotha! You too!
Didn't have enough fuel to stay in the tank pick up for the full run. That pass would of/should of been in the 10.50's going off his 1/8 trap and speed. I've got a iPhone video of right beside the car at the line and it looks like it got catapulted off the line it left so hard. Well deserved Elliot!!!
Thanks bro!
Thanks brotha! You should hear it in person.
Don't know about that, but thank you very much.
Thank you!
thanks
PLATINUM SPONSOR
Very nice and love the neck breaking launch!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
1 Post
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
great video,,, I can't wait to see the video of 10.73 @ 129mph run..
great runs really made the trip worth while.
as for the ones of us that couldn't go you made us proud jim
#32
Thanks! I broke my stock diff and rear driver axle not to long ago. So I bought the rear end off the car Craig was parting out. We put a Quaiffe in and this was the third time I've been to the track. And perfect prep always works.
Thanks man! She has a little more left.
Thanks! I stall at 1500rpms. Any more then that, my car starts pushing through the breaks. BTW I shallow stage also.
Thanks Andrew! It was a pleasure finally meeting you!
Thanks man! It was very nice meeting you!
Thanks Brooke!
Haha thanks Jim.
Thank you!
Yes it was the lack of fuel in the tank. I thought there was more in it. My fault! And my car has both front and back seats pulled. There is a carbon race seat with a roll brace that bolts in. And I'm tuned on Q16. The car dyno'd at 549hp/594tq before we left. Other than that, this run had stock fronts at 55psi and clk wheels with Hoosier radials 22psi and stock battery.
Thanks Brooke!
Thank you!
#36
#37
