Shifting Issues
The car will be in second or third gear, ill be going about 30mph, when i step on it the car downshifts to first gear then when it goes to shift up it just has this 1-3 second pause holding 6200ish RPM. After I did the tune it will even bounce off the rev limiter a few times then finally shift. Is this common.
https://mbworld.org/forums/w211-amg/...set-works.html
