High Stall Torque Converter
Old Feb 9, 2014 | 07:09 PM
  #51
e55amgrocket's Avatar
Dirt Scooters
Originally Posted by 99lightning
ok folks seems like you are all missing alot of my well documented data stock no stall no tune 11.9 at 116, then a tune in minus da 11.6 119.9mph dead hooking. Now i added a stall no more dead hooking and in warmer air and 800 positive da i ran 11.59 at 120mph. so for guys wondering about tunes and stall convertors here is my experiences and the times with the weather and traction all show a gain.
Your missing something also. Dead hook, no hook, might hook, won't hook means nothing. Actual 60ft times I each run do.
Old Feb 9, 2014 | 07:32 PM
  #52
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by dllhg
99 hit 11.59 .... I seriously dont think the tune added much to his times. Guys have hit 11.7s bone stock with DRs. An 11.4-11.5 wouldnt be a big deal at all with a good stall and a TCU that is tuned for it. Driver mod too of course.
After those two posts, any question as to how much a tune adds? The 1 or 2 bone stock cars that ran 11.7 were factory freaks on perfect tracks with big negative da numbers.
Old Feb 9, 2014 | 07:42 PM
  #53
chiromikey's Avatar
It's not that we're missing your data, we're going off nearly 10 years of our own data...
Old Feb 9, 2014 | 08:01 PM
  #54
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
Originally Posted by e55amgrocket
Lol I dropped 4 tenths on my first run with a tune from OE. I had been running all day at a rental when I first bought the car. Jeremy from OE was there and sad he would put a tune on the car and let me make a few runs and see if I liked it. First run was .4 faster and every run after that was the same. Yes a tune makes you run faster. As for lsx cars of course a higher stall will help on a turbo car or centrifugal blower not to mention the stalls on those cars are 1700rpm. By the way this isn't my first time drag racing either .
The only way to really compare two runs is have the same DA and look at MPH. 4/10ths seems like an awful lot from a tune. Are these cars gaining over 50 WHP tune only ? Was that ECU only or TCU as well ? TCU I could see it. Also Jeremy from OE seems to be a very gifted tuner. I really need to get a custom dyno tune from him ASAP. I know I am leaving a LOT on the table...
Old Feb 9, 2014 | 08:04 PM
  #55
dllhg's Avatar
No not true. Hammerdown ran is 11.7 at Sac which has the worst track prep ever. It also doesnt have really low DA very often. I believe there are quite a few stockers with tires that have gone in the 11s.
I'll just say I think you guys are wrong about how much gains you can get from a stall on any Auto car. All the fastest street driven autos have high stalls. I dont see why a Benz would be any different.
Old Feb 9, 2014 | 08:52 PM
  #56
chiromikey's Avatar
Sac's rep about bad prep has long been proven wrong. Sac holds some of the records for quickest/fastest e55's known! I ran a stall in my first E55 so I know what they're worth. 1-1.5 tenths in the 60ft and 2-3 tenths MAX at the end of the track (if you're already launching to the car's potential).
Old Feb 9, 2014 | 09:03 PM
  #57
ec_nova's Avatar
E300, C63
this will be my third and last post on this forum unless I need to PM someone to buy something. The ignorance is unbelievable!
Old Feb 9, 2014 | 09:10 PM
  #58
chiromikey's Avatar
Says the guy that just stepped foot into his first E55!
Btw, I just noticed your sig says you're driving a 2015 E55. My bad, I have no idea how that car will respond to a stall converter.
Old Feb 9, 2014 | 09:19 PM
  #59
E55Greasemonkey's Avatar
This place is a joke.
Don't forget to make a 4th post when your otherwise stock E55 with just a converter runs low 11's. Oh wait, that means this IS your last post.
Old Feb 9, 2014 | 11:31 PM
  #60
Dirt Scooters
When I dropped 4 tenths after the tune it was a 20 minute gap between my other runs. Same day,same temp, same DA. Just a ECU tune no TCU then.
Old Feb 9, 2014 | 11:38 PM
  #61
Dirt Scooters
Yes your ignorance is unbelievable that's for sure. Feel free to PM me when you run that low 11 too
Old Feb 10, 2014 | 02:01 AM
  #62
dllhg's Avatar
Really its pretty damn bad most of the time. At least for Test and tune it is. I couldnt get my GTO to dead hook at all and it was only 450 WHP. With good DRs smoking burnouts and lots of runs I never did better then 1.85. You never see them spray VHT on it. Almost never sweep it. The left lane is consistently much much worse than the right lane every single time I have been there. 2-3 tenths may be all its good for but that is still quite a lot and enough to put an E55 into the mid 11 second range.
Did you like the stall on your E ? Pros and cons ?
Old Feb 10, 2014 | 02:04 AM
  #63
dllhg's Avatar
What about trap speeds ? A couple tenths or more can easily be driver mod. If your MPH went up a few MPH I would be very impressed indeed. Wouldnt surprise me with a tune from that guy. He is the same guy who did a custom street tune on Hammerdown's car and he has pulled 10.8s full weight and a lot less mods than many who run those times.
I need a custom tune badly. I ordered a TCU tune from EC when they had that $250 special. Just waiting for the loaner to arrive. Cant wait to see how much it helps. My GTO when it was stock that mod dropped 3/10ths and gained 2-3 MPH with no other changes.
Old Feb 10, 2014 | 02:47 AM
  #64
chiromikey's Avatar
Off the top of my head for the 3000 stall
Pros:
-makes big pulley cars easier/smoother to drive on the street
-quicker 60ft/et's
Cons:
-TCU tune is a must. Some car's TCU will not understand how to interpret the difference and forget how to downshift on mild-moderate acceleration unless you go full throttle.
-3000rpms is overkill imho. These cars make max TQ by 2000rpms so with the lack of drive train upgrades, there's too much risk and not enough reward to stall above that (I've already twisted an axle and ruined a diff).
Old Feb 10, 2014 | 11:57 AM
  #65
Dirt Scooters
Mph went up 3-4mph. It's been awhile but I remember being stuck at 114mph stock that day (it's was in the high 70's) and the first run with the tune I went 117 and was so amazed I got lapped it a few times to see if it was a fluke and it wasn't. A tune is huge one these cars and ET wise on of the biggest gains you will see as far as mods go.
Old Feb 11, 2014 | 10:36 PM
  #66
dllhg's Avatar
Pros:
-quicker 60ft/et's
Cons:
Good info, thanks. My Supercharged GTO had a 3K stall. I went from an NA stock GTO to that one and I sure didnt notice any loose feeling like many people describe. Most likely because of all the low end torque I gained from the blower. I would think a smaller stall on this car would be really helpful at the strip and daily driving from a roll. A few tenths for around $1500 installed would be a good choice for a lot of people on here wanting more out of their car.
These cars must be pig rich from factory. Also he probably removed the TQ management from engine side. I wonder what these cars can do with a good ECU and TCU tune only and tires. Still waiting for my TCU .... Going to pull the trigger soon and get a dyno tune.
Old Feb 11, 2014 | 10:56 PM
  #67
MAN55LE's Avatar
04 E55 AMG
Shardul sent you pm
Old Feb 11, 2014 | 11:01 PM
  #68
Dirt Scooters
I'm guessing your GTO was on street tires? I had a 05 gto 6spd with bolt-ons running 11.60's then low 10's with a 440lsx with mozez heads. I seem to like drag racing heavy cars that aren't really the best for drag racing lol. IRS was a nightmare that I should of known better from my terminator days.
Old Feb 12, 2014 | 02:25 AM
  #69
dllhg's Avatar
No was on DRs. Couldnt do better then a 1.85 60 foot. I had the smallest least efficient blower you can get, Maggie 112 along with shorty headers .
Bolts ons and weight reduction ? Those seem like amazing times for bolt ons. I know there are a few members with crazy times like that without many mods but there are very few. Most guys have decent sized cams to run mid 11s. My car could have run an 11.5 with a much better 60 foot but that would be about it. Damn low 10s all motor with a 440 or did you have a blower too ?
Old Feb 13, 2014 | 10:45 AM
  #70
blackbenzz's Avatar
haters crazy
Easy way to settle this. Measure how many times the traction light blinks before and after the mods lmao. If you want to go low 11s with a single mod put it on the bottle
Old Feb 13, 2014 | 01:02 PM
  #71
jcjmw's Avatar
2005 E55 Wagon
Pros:
-quicker 60ft/et's
Cons:
I forgot that I had my TC installed just a few months ago. I agree it makes my car smoother/easier to drive on the street with my pulleys. As for the rest of pros and cons, I really do not yet know.
Old Sep 3, 2025 | 08:31 PM
  #72
Bab26's Avatar
E55 w202 2.3 turbo
E55 m113k torque convertor
Hello do you sell e55 m113k higher stall torque convertors?
Old Sep 3, 2025 | 09:15 PM
  #73
SICAMG's Avatar
2005 e55 AMG
ECS tuning has them in stock.
Old Sep 3, 2025 | 09:25 PM
  #74
Bab26's Avatar
E55 w202 2.3 turbo
is it same onw they are talking about?
Old Sep 3, 2025 | 10:08 PM
  #75
SICAMG's Avatar
2005 e55 AMG
Yes looks like it
