well it's starting.. Time for Mods!!!!
well I just picked up My car Last week. which turned out the be a Kleemann K4.
and looking over the car it still has the factory Intercooler pump and H/E So first set of mods is gonna be a Larger H/E, split cooling system and Johnson Pump
Put some New shoes on also. My buddy had them laying around(had them on a 94 E500) but were to big.. they are 19" e63 re-pops. I am gonna lower the car this week(Star) along with Valve cover gasket, tranny fluid and connector 1 heat range colder plugs and oil change. I work at a shop In santa monica..
Also The car never came with a TCU tune. So that looks as if it need to be done also and go to a larger crank pulley. it has a Kleeman 168mm crank pulley. so I was thinking 17x or 180mm and advice...
in sport 2
comfort.
in sport 2
comfort.
I'd stick with the 168mm pulley. Any larger and your going to be creating lots of heat, as well as a useless first gear and a lack of traction.
https://www.easyperformance.com/prod...ost-controller
although the pulley wont get done for a month or so. I still need to dyno for base line..
was not able to test due to rain when i went and pick it up.
close to stock car. My car has the headers but they left the factory resonator and mufflers. I and gonna re-do with x-pipe and get rid of silencer.
I will make a better one...
http://s2.beta.photobucket.com/user/...70582.mp4.html..
Nice pick up!
Fwiw if I bought my car with K4 installed I wouldn't touch the engine.
Cosmetics and TCU tune...absolutely.
I think the K4 package is one of the best all around sorted options for our cars.
Certainly you can add more torque, but I am not sure the gain will be worth the downsides.
Kleeman really knows what they are doing with our engines and have a great balance of USABLE power, efficiency and safety.
Welcome and good luck.
well I star lowered it. Also did the tranny connector,what a difference as far as shifting.
oil change,(Mobil1 0-40) K & n filter clean. Apparently nobody in 30,000mi thought they needed to be cleaned.
Kleemann headers
going to do something about this. most likely x pipe with new cats and get rid of resonator
Kleemann headers
