Fanatics get in here and help me solve an airmatic puzzle please!
In lowered mode sport 2 setting I'm ok in the front but my rear right side is sitting on the ground. Also, the car is constantly correcting in the rear, going up and down a couple millimeters. Parked in lowered mode sport 2 I'm on the ground as well.
However, in off road mode raised sport 2 setting, the car is fine. In fact, driving or parked, it stands nice and tall. I understand that the pump is constantly correcting when the car is on but even overnight when I leave it in off road mode the rear stays up and high, it does not sink to the ground.
I understand the pump is constantly correcting in the event of a leak. However, wouldn't the car eventually lower when turned off? My car has been parked overnight in off road setting and it's in the same position as I left it. It seems to only hit the ground when it's on and in lowered setting.
My question is, is there anything else that could be wrong other than a hole in the airbag?
2004 E55 AMG
My guess would be that the rear height sensor has a bad spot and is sending false information. Its probably just a simple potentiometer. When you raise the car it moves out of the bad spot and works properly.
Just a quick update:
Car has been sitting in the garage for the past 48 hours in off road mode and it has not lowered a millimeter.
> I start car
> put in low mode s2
> rear end is on the floor
Any thoughts?
> I start car
> put in low mode s2
Any thoughts?
