Headlight upgrades :)
Old Dec 23, 2012 | 07:38 PM
3BNick's Avatar
2006 E55
Not satisfied with the output of my OEM bi-xenon headlamps and the slight opacity of the old original lenses, I have decided to make some updates.
First, I started with wet sanding and clear coating the lights with a very high quality clear to remove the outer haze and provide UV protection to keep them from yellowing again which only led to the discovery that there is still haze inside the lenses itself. While I was in there, I tossed in a pair of 5k D2S bulbs to replace the old tired OEMs. Both of these steps combined made a great improvement but I'm still not happy.
Having active xenon lights doesn't give me an affordable option to just replace the whole assembly with the E63 units so I have sourced a set of DEPO aftermarket housings which I will gut for the lenses and reflectors to get the newer "facelift" look. I'm also going to replace the projector lens for a clear lens to clean up the cut off line and also modify the cut off shield to enhance cut off color. To finish it off I'll put in a set of Osram CBI bulbs to make sure I'm getting the most of my set up.
The only possible cons to doing this is losing some of the light dispersed above the cut off line that the original non clear lenses provide(which my 5K HID fogs will make up for) and the down time to do the work. Ideally, I will have this all done in one day provided all parts are correct. I need to verify stock projector lens size so I can order my new ones. Anyone ever tackle this on the 211?
Old Dec 23, 2012 | 08:53 PM
justinwrock's Avatar
Ducati
you should retrofit a better projector unit while your in there.
the glass that was/is used on the w211s isnt exactly the greatest.
Old Dec 23, 2012 | 09:19 PM
3BNick's Avatar
2006 E55
I would definitely retro in something nicer, but I'm not sure I would be able to keep the active cornering and leveling feature intact. Any one have some insight on this?
Old Dec 23, 2012 | 11:23 PM
Jakez's Avatar
'03 E55 AMG - '06 300C SRT8 - '93 240SX Coupe w/1JZ-GTE
So if I don't have those features on my headlights I can just simply replace them with e63 ones?
Old Dec 23, 2012 | 11:33 PM
black06c230's Avatar
mgLipGD
I have done all this except swap out the covers/chrome trim for the facelift using the DEPO units. I have the active headlights as well. I used the ZKW-R lens and the CBI D2S bulbs. I have 5k fogs on my E63 conv as well. Light output is GREAT!!!
Old Dec 23, 2012 | 11:42 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
I did this on my E500 and CLS but kept the OEM headlights as DEPO sucks
https://mbworld.org/forums/e-class-w...lly-seeee.html
Old Dec 24, 2012 | 08:02 AM
3BNick's Avatar
2006 E55
Have any pics? Also, are they just 3" lenses? I'd like to order everything all at once before I crack them open.
Old Dec 24, 2012 | 08:13 AM
3BNick's Avatar
2006 E55
I just looked through Djrabbi's thread and found a link to the lenses. The output on your e500 is killer! Exactly what I'm looking for. It almost seems like the OEM HIDs perform like halogens compared to all the Lexus and Acura cars out there.
I only want the DEPO housings for the new outer lens covers and the inside bits to convert my E55 housings to E63 look housings.
Old Dec 24, 2012 | 09:47 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
If yours work out well I may see if you want to make some money and do mine... I'd love to meet up and see the output when you're done. I just upgraded the raptor with the 2013 headlights with Evo-R projectors and some led work. I guess it's not too difficult. It's the projector lens swap on the active lights that scares me.
Old Dec 24, 2012 | 09:56 AM
djrabbi's Avatar
I am going to retrofit my CLS projectors to the newer RX350s. Should be bad ***
Old Dec 24, 2012 | 11:02 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
Damn, someone do a write up on this, I kind of want to paint my housings so I would replace the lens the same time. I did a 55Watt conversion on my M3 xenons and then did the fx-r conversion but really was hoping to leave these headlights alone
Old Dec 24, 2012 | 11:04 AM
djrabbi's Avatar
Kind of like this?
Old Dec 24, 2012 | 11:22 AM
3BNick's Avatar
2006 E55
Sterling, once I get these done I'll be more than happy to let you check them out. Since you are local I'd be willing to help you out. From what I see, changing the lenses appears to be as straight forward as any other non active/dynamic projector. The raptor looks good btw.
I'll be sure to document the process here for you guys. So far, estimated cost of parts will be around $300 for the DEPO housing I'm going to butcher, $185 for the CBI bulbs, and $40 for the ZKW-R lenses.
Old Dec 24, 2012 | 11:30 AM
djrabbi's Avatar
I might have a butchered OEM E63 headlight is someone wants it but only 1
Old Dec 24, 2012 | 11:44 AM
55fanatic's Avatar
Yup, like that, but a satin black I think... I'm going back and forth on dechroming the car...
Old Dec 24, 2012 | 11:45 AM
djrabbi's Avatar
I did mine satin gunmetal.
Old Dec 24, 2012 | 11:47 AM
3BNick's Avatar
2006 E55
The black housings look great. I may have to spray mine while they are open. Yours look way more aggressive.
Old Dec 24, 2012 | 11:49 AM
djrabbi's Avatar
Make sure you try to get ZKW rather than the reps. I have OEM ZKW and much better than the R. Not much difference but the cut off is much sharper
Old Dec 24, 2012 | 11:54 AM
3BNick's Avatar
2006 E55
Thanks. I'll try to find the non repro versions. Any links?
Old Dec 24, 2012 | 11:56 AM
djrabbi's Avatar
TRS might have them.
Old Jan 15, 2013 | 08:24 PM
pnoyworx's Avatar
10 E63, Sold -07 E63
djrabbi, how much would you do my retrofit?
