Single air filter?
Old Jan 2, 2013 | 01:54 PM
Jakez's Avatar
'03 E55 AMG - '06 300C SRT8 - '93 240SX Coupe w/1JZ-GTE
Single air filter?
Has anyone tried putting like a small pancake filter on the throttle body? I know it would be sucking in hot air but would it be a bad airflow like that?
Old Jan 2, 2013 | 02:06 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Not a good idea. Even though you may be gaining some air flow, the hot air will pull timing.
Old Jan 2, 2013 | 02:28 PM
Toadster's Avatar
2005 E55 AMG
unless the hot air can be addressed, I still think a cowl induction hood would be neat, although not really very functional with a S/C based motor
Old Jan 2, 2013 | 02:31 PM
Jakez's Avatar
Thought ive read on here that the hot air issue is irrelevant since its supercharged and the air will be cooled afterward anyway..? But yeah what youre saying makes sense I guess.
Old Jan 2, 2013 | 08:12 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
No, it's very relevant. The hotter air you are sucking in the hotter it will get after it is compressed. You want to start with the coolest air possible so your intercooler will be able to get the temperature of the boosted air closer to ambiant.
When you suck in very hot air, your intercoolers can't cool the air down enough and you get heat soak quickly and it kills your HP. 1% hp loss for every 10 degrees of heat. Sucking in hot air over 200 degrees is not a recipe for making more power.
Old Jan 3, 2013 | 09:46 AM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
This has been done and there was huge power lost top end.
