05 Mercedes E55 AMG Transmission problems?
Old Apr 18, 2013 | 09:32 PM
BlackOmega's Avatar
2000 E55 AMG
The air intake tubes? O.o
Just for future reference, the way these transmissions work when you remove your foot from the throttle, they act like a manual and stay in the gear you were in and slow you down. That is totally normal operation.
Old Apr 18, 2013 | 09:39 PM
Carterhkrs's Avatar
2005 Mercedes-Benz E55 AMG
Originally Posted by Crissus
Interesting +4
I always thought that rough shiftings and stuttering on very slight throttle, with fresh fluid and correct level, comes from the torque converter clutch, or its responsible "valve" at the conductor plate, which was to small in early versions IIRC.
Thought it was tranny or conductor plate as well but then remembered having same issue with e53 x5 it kicked even harder and later on started to die on every stop, one of inlet tubes was disconnected complitely,
Funny that none of three shops i came in to check why my w211 kicks were able to find this problem, they all kept saying its normal!
Old Apr 18, 2013 | 09:43 PM
Carterhkrs's Avatar
Have no idea how transmission on these cars work but kicks were ugly after removing foot from the throttle, after fixing air tubes in place kicks not present anymore, normal slowing down and hard kicks are two different things
Old Aug 28, 2013 | 01:07 AM
huy's Avatar
huy
2004 E55 AMG
are there supposed to be hose clamps on there? i don't have any on mine.
Old Aug 28, 2013 | 05:20 AM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Depends in which program you drive...
On "E" mode (and depending on your learned driving habits) it happens even down to 1600rpm that the gearbox would upshift when you remove your foot from the throttle. On "S" mode it keeps the gear though.
Those are my finidngs in the CL with the same gearbox/TCU
Old Aug 28, 2013 | 07:18 AM
S2K750's Avatar
Daily 06 E55, Fun 12 GSXR750, Racing John Deere D110
There's no rev match feature like on the newer cars... Blip the gas like a manual and it's smooth.
Old Aug 28, 2013 | 08:48 AM
  #32
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
I don't have any either. I do see where the tubes have a raised bump that's normally indicative of a screw clamp with the rubberized bottom and a slot to keep it from rotating.
Old Aug 28, 2013 | 09:28 AM
  #33
berti_00's Avatar
2016 Cls63s AMG
let me i help you shift it
Old Aug 28, 2013 | 09:45 AM
  #34
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Originally Posted by berti_00
Genius!! I wouldn't trust my car to anyone else
Old Feb 13, 2014 | 10:54 PM
  #35
Mulletmudbogger's Avatar
Bus Honda accord bus
After reading this thread I'm a little confused how a gap in your intake tube could cause a downshift clunk or whatever it is
My goofy intake tubes are a little loose but could someone confirm that this could cause a transmission problem?
Old Feb 14, 2014 | 12:42 AM
  #36
tee's Avatar
tee
E55,GL 450,Subaru STI,Chevy crewcab
No way was this causing the trans to shift hard these tubes are normally loose fitting
Old Jun 22, 2017 | 11:01 PM
  #37
driffydre's Avatar
'03 E55, '00 GS300, '15 745I '13 M6 Gran Coupe
+1
