Wimpy Stereo
Old Aug 4, 2003 | 08:47 PM
akinder's Avatar
2001 E55 AMG
Wimpy Stereo
I hope this one hasn't been done to death, but I'm wondering if anyone has a recommendation on a power amplifier that will work with the stock radio.
I have a 01 E55, I want to keep the standard radio and hopefully the speakers as well.
I'm disappointed though with the volume of the radio. I don't want to 'thump', I just want to be able to listen to radio/CD's louder, whether it's hard rock or country.
Are there any special requirements? I heard the CD changer had to be special MB brand, so I had that dealer installed.
Can I take it to the local Circuit City or Best Buy and have it done or does it require special skills?
Anyone done this?
Old Aug 4, 2003 | 10:29 PM
kaneman's Avatar
You won't be able to keep the speakers but you WILL be able to keep the stock radio. I put a stereo in an '01 CLK55 and the systems are largely identical (and identically awful). I replaced the speakers, disconnected the stock subwoofer and added a 10" sub in a small isobaric box along with two amplifiers to drive everything (one had a crossover built in that I used). I also added a parametric EQ to cancel out some of the equalization in the stock Bose setup. The result was VASTLY improved sound. Higher highs, lower lows and lots of clarity. I recommend a fairly large amp, at least 50 watts per channel and 150-200 for the subwoofer (Infinity makes a great sub called the Basslink that's amplified and does a fine job).
Old Aug 5, 2003 | 05:48 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
kaneman is exactly right. You will not be able to keep the factory speakers if you replace the amp. Do you have a Bose system? Those amps and speakers run on 2ohms and the standard car audio systems run on 4ohms. Mixing the 2 will cause the sound to suffer.
