Ec tune + 550 injectors = terrible idle and drive?
#51
2005 E55
No codes. I also have the problem at times while driving at 60-70. The car will buck, the afr will be in the 16 range. If i try to accelerate, it will go to 18 and full lean. Fells like the fuel pump is failing. I cant figure out why it only does it when driving at light loads for over 5 miles. It is like it goes into an economy mode. Others on this forum have had exactly the same problem. I have not seen a cure.
#54
I have this exact smae issue, being caused by the same thing of light throttle application at hwy speeds for an extended period of time. Gotta be something in the tune. Never did it before the 82mm. I have also heard others having the issue to. I am tripping a Map sensor code though P0105. I feel the buck at hwy speeds and my stft's max out at +25%. the ecu will find 14.7 but you can tell its struggling. If I pull over and restart it all goes back to normal
. Going to be getting it checked out sometime next week, will see if Speedriven knows anything about raising Map Sensor voltage in the tune. I have been told by a few people this is the problem
#56
Dont rule out the fuel pumps, mine would only show a problem after 5500 rpm, if they are on the way out then they could be intermittently be inturrupting the fuel supply.
#57
Mine was done 23K miles ago, so don't think it should be an issue. This is actually happening at low RPMS, My WOT is perfect AFR's all the way up to 6500
#59
Received 1,488 Likes
This place is a joke.
Just a theory, but the ECU may have a cruise/economy table when it detects what would be your highway driving. The throttle position sensor voltage also playing a part, and now with a larger TB there is more air coming in vs the stock TB at the same voltage or throttle position-meaning a leaner mixture, and possibly the ECU not able to or confused as to how to compensate. If it throws a code for the MAP sensor it may then go to a fixed default value based on the throttle position. Again though, this throttle position is technically not correct with the larger TB. Hard to explain. And a slow or bad O2 sensor will not always set a code.
#61
#62
2005 E55
I am driving my car every day from now on with a star tester connected. I think it is in the tune or TB.
I used to tune Mercedes with Kleemann. What i learned is that there are batches of control units. Each has a different checksum value for the hex code written and changed in the ecu for the tune.
With this said, i wonder if some batches have a different base tune which, even when modified doesn't compensate enough.
#64
2005 E55
Quick update. I have been dataloging with star tester. So far the engine will not act up with star connected.
THIS MAKES ME WONDER! Does the controller go into a special mode when connected to star, or is it eating some of the can data that could cause the problem...
I wonder if the trans controller could tell the engine controller to lean out because it thinks it is about to shift? Just thinking out loud.
#66
i'm sure he'd be aware of that. if you weren't aware of the fact you don't have esp then he has no business tuning his car in the first place...
#68
'06 E55
I am also having the hiccup issue. I'll rule out the fuel pump as I had a brand new one installed a few thousand miles ago thanks to the infamous leak.
I'm about to try a 90mm and see if it continues. For me, the problem is easily repeatable as it happens in almost the same place in my morning commute, I get on the highway, after a few minutes, cruising constant 75-80, I go down a hill, and then up another one. If I keep the speed constant, about 1/3 of the way up the hill, once the load gets high enough on the engine, it does the hiccup. I have tried it in 4th and 3rd gear and it will still do it despite the increased rpm. If I am going 80, let off the gas until 75, 1/2 throttle it back up to 80, coast to 75 and keep doing that until I am at the top of the hill, I can avoid the hiccup.
I am bumping up the idle tomorrow with star and I will see what happens.
#70
2005 E55
Yes. I have confirmed that some of our contol units do this...now i have to figure out why.
It is not the engine or equipment... It is in some our ECUs.
#71
'06 E55
My issue is fixed!!! Super happy and it was an easy fix. I don't know how it got by so many sets of eyes, but driver's side way back by the throttle body, there was a hose disconnected and that rigid hose that is part of the evap system. I found the leak using brake cleaner and my mechanic found the hose when I pointed out where the leak was. If you are having these symptoms, pull off the driver's side airbox and follow that rigid black hose on back. Removing the Y-pipe will aid in finding any hose problems back there.
TPS is now at a steady 2.0% at idle in gear when before it was hunting around at 0.7%. I cleared the codes and the P0505 and P0507 codes have not come back. I am also free from that damn gas cap warning. She idles and drives smoother and with the pulley reshimmed, s/c engagement is much better.
Last thing I have to fix is a P0141 and then I'm good to go.
#72
2005 E55
Good to hear! I have no leaks and NO check engine light or codes.
I have adapted to the higher idle which has cured all codes. I have driven almost 10k miles since the mods and the only problem is as described.
#73
'06 E55
Just so you know, I have replaced the fuel pump (due to the infamous leak/smell) and gas cap (due to dash warning) within the last year. I have the TTM fuel rail and injectors.
Being a master tech, I'm sure you've done the brake or carb cleaner vacuum leak test. I found mine by spraying down between the TB and surge tank on the driver's side, kinda deep down in there.
