BIP 3000 stall convertor review
99 ford lightning
My friend through this it at cbtuning yesturday. I just drove the car this am normal driving feels like stock other then it will rev up quicker as you drive. 2nd gear before the stall fell lousy to me when you just punched it from a roll, now if you do that it just burries the tach and the tires go up in smoke. Otherwise if you just get into it pretty good without wot the car will pull real nice better then before. Now when it shifts 3rd you will feel that shift because of the lock up clutch but thats what im use to im use to actually having my teeth rattle from the lock and unlock. from there it just pulls like a freight train. with the car in park it revs up quicker too. Im sure it has to help my quartermile times. Now like i said it will take a bit to get use to for the average person you will def feel the lock and unlock now not thats a bad thing but thats what its suppose to do. I could easilly do a rolling burnout in 2nd from a roll now kind of fun. I also brake stalled it up to 2500 rpms no prob obviously i didnt take off from there kind of pointless save that for the track. seems ok so far i will do more driving tomorrow with it or later i need 2 front tires one of mine is bad bulging on the inside.
PLATINUM SPONSOR
When are you going to the track? Like to see more videos
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
99 ford lightning
soon still super hot out here my track close to me island dragway in nj opened up again so i dont have to hike it down to atco. The only thing holding me back is that rear its real tricky getting both tires to spin during a burnout i almost have to flick the tires and do a top fuel burnout.
