e55 aeroforce guage updates.
Gauge 1 (engine control module)
1. Intake Air Temp
2. Coolant Temperature
3. RPM
4. Boost – inHg/PSI. Derived from MAP sensor subtracting barometer.
5. MAP kPa – Manifold Absolute Pressure displayed in kPa
6. MAF lb/min – Mass Air Flow Sensor
7. Throttle Angle
8. Ignition Advance
9. Engine Load
10. MPG – Calculated miles per gallon
11. HP – Calculated HP at crank
12. Battery – battery voltage
13. Inj. PW 1 –Injector Pulse Width for injector #1
14. Inj. PW 2 –Injector Pulse Width for injector #2
15. Oil Temp
16. Oil Level mm
17-24. Knock C1-C8 –knock retard cylinder 1-8
25. O2 B1 mv – O2 sensor output for exhaust bank 1
26. O2 B2 mv – O2 sensor output for exhaust bank 2
27. Analog 1 – analog input 1
28. Analog 2 – analog input 2
Gauge 2 (transmission control module)
1. TCC Slip – Torque Converter Slip
2. TCC Slip DSRD –Torque Converter Desired Slip
3. TCC State – Torque Converter status:1=unlocked, 2=partial lock, 3 = lock
4. Gear Actual –Current transmission gear
5. Torque – torque delivered to transmission
6. Output shaft –transmissoin output shaft speed
7. Gear Target –Transmission target gear, will updated just before shift occurs.
8. RPM
9. Turbine in SPD –engine output shaft speed
10. TCC DC- Torque converter clutch duty cycle
11. Analog 1 – analog input #1
12. Analog 2 – analog input #2
If you are adding temp sensors you can buy temperature sensor kits that also use the analog inputs.
If you are using a lot of additional sensors there is the Analogic gauge which looks identical but has 4 0-5v inputs and 2 egt's. This one does not plug into the OBD2 port.
Todd
Nice clean gauge set up though.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Need Real Time data Please !
Personally I think an oil temp and oil pressure gauge would be much more beneficial....As well as a transmission temperature gauge....And it appears this gauge would be great for the various analog inputs....
