Power steering pump and fluid
Old Feb 9, 2013 | 03:35 AM
GT-ER's Avatar
2005 E55 AMG
Originally Posted by Sir-Boost-a-Lot
Probably the cap, but I haven't examined it. It's got to be vented somewhere to account for thermal expansion of the fluid. It will expand around 7% in volume from a cold morning to a spirited drive with a hot engine.
The radiator liquid will expand as well and it's a sealed system, but it's pressurized so maybe you are right. Perhaps the cap is built it seal it until it builds some pressure and releases it when needed.
Old Feb 9, 2013 | 10:48 AM
Quadcammer's Avatar
96 and 08 911 turbos
hence the different "max and min" levels for 20c and 80c on the dipstick on the cap.
Its not vented.
Old Feb 9, 2013 | 12:42 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Of course it is vented. Do you suppose if you fill your PS reservoir cold and then drive, your system is under pressure, putting stress on your oil seals?
The different indicators on the stick are to show you where the levels should be at different temperatures to account for fluid expansion.
Its not vented.
Old Feb 9, 2013 | 01:02 PM
03'55AMG's Avatar
AMG
Either way, I think I found my leak. Front engine skid plate. Its all dried up, and there is no new fluid. So I topped it off, and drove around and now my steering is great again!
Old Feb 9, 2013 | 02:06 PM
Where was it leaking from?
Old Feb 9, 2013 | 03:11 PM
Quadcammer's Avatar
You're right its vented.
That said, I can't imagine that hydraulic fluid like pentosin will evaporate to the extent that it would significantly reduce the fluid level.
Old Feb 9, 2013 | 10:33 PM
  #32
03'55AMG's Avatar
AMG
Haven't found the actual leak yet, just know that its there.
