Power steering pump and fluid
Old Feb 2, 2013 | 11:59 AM
03'55AMG's Avatar
AMG
I noticed today that my PS pump is literally almost out of fluid... There is no leaks and the dealer filled it up 2 years ago, Do these pumps eat up fluid? What fluid should I throw in here? Just any synthetic fluid? searched and found info on leaks and one "going nuclear", but nothing on fluid. What do you guys run?
Old Feb 2, 2013 | 01:26 PM
GT-ER's Avatar
2005 E55 AMG
Mine is the nuclear.
Old Feb 2, 2013 | 01:49 PM
berti_00's Avatar
2016 Cls63s AMG
Man you have no luck lol... make sure its full to the level it needs to be
Old Feb 2, 2013 | 02:46 PM
desired_speeds's Avatar
2007 SL55 AMG
OEM MB PS fluid.
Old Feb 2, 2013 | 02:58 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
03-55amg
not checked your fluid in 2 years, what do you smoke besides your lights? anyways check your steering rack, it is probably leaking into the plastic belly pan under the car, the rack is the long piece with the two rods coming out one on each side that attaches to the wheels. There will be two hoses attached, also a point of possible leakage. There are plastic bellows which cover the tie rods, if no leakage is seen anywhere else, take a sharp awl and poke a hole in the bellows on either side at the bottom to see if the fluid is in the bellows. Good luck
Old Feb 2, 2013 | 03:10 PM
novae500's Avatar
W211
Man time to ditch the car and get a newer one....PS fluid you need is Pentosin ch11 its green metal can. $24/liter
Old Feb 2, 2013 | 03:41 PM
03'55AMG's Avatar
AMG
will any fluid work?
Old Feb 2, 2013 | 04:00 PM
Quadcammer's Avatar
96 and 08 911 turbos
no, use the pentosin.
11s or chf202
oh, and the pump does not "eat" fluid. If its low, you have a leak.
Old Feb 2, 2013 | 07:07 PM
berti_00's Avatar
2016 Cls63s AMG
Id do a flush and while at it make sure you get a new resivore it comes with two new rubber seals and ur good to go
Old Feb 2, 2013 | 10:43 PM
GT-ER's Avatar
2005 E55 AMG
Two rubber seals? I've replaced two reservoirs in two cars and they have had only one seal.
Old Feb 3, 2013 | 07:43 AM
03'55AMG's Avatar
AMG
I noticed on another thread that the PS pump is almost universal on all Mercedes, with only the reservoir changes. Where can I get another one?
Old Feb 3, 2013 | 09:55 AM
berti_00's Avatar
2016 Cls63s AMG
i might be mistaken might be just the one that goes all the down on to were you hook your hose up.... could of sworn there were two
Old Feb 3, 2013 | 10:04 AM
Quadcammer's Avatar
only one seal.
Why are you replacing the reservoir? Its a piece of plastic. You can replace the seal if you think its leaking from there, otherwise there isn't much point.
Old Feb 3, 2013 | 10:20 AM
berti_00's Avatar
2016 Cls63s AMG
Originally Posted by Oliverk
only one seal.
yah i searched it and saw one only... why its because its cheap and the tech at the dealer said if am not wrong it has some sort of i dont wana say sponge but something that collects dirt and such
Old Feb 3, 2013 | 10:32 AM
03'55AMG's Avatar
AMG
Exactly, I have heard there a little filters built in. So might as well replace it as maintenance
Old Feb 3, 2013 | 11:36 AM
GT-ER's Avatar
2005 E55 AMG
only one seal.
I've been told by a few people that the reservoir has a built in filter. One of those people is a guy I have always found very knowledgable when it comes to MB so I don't know.
Old Feb 3, 2013 | 03:33 PM
03'55AMG's Avatar
AMG
+1. I am not throwing names, but I can count on the Guy who told me anyday.. If he were wrong I would be shocked.
Old Feb 3, 2013 | 07:31 PM
GT-ER's Avatar
2005 E55 AMG
BTW- It DOES have a filter:
http://www.benzworld.org/forums/w163...reservoir.html
Old Feb 4, 2013 | 12:28 AM
grane's Avatar
GLK350, SL63 AMG
11S I'm fairly certain - check OM
11s or chf202
Advance Auto Parts regularly stocks both Pentosin fluids at a favorable price. It is also used in the ABC system on cars that have that system. Why pay more?
Old Feb 4, 2013 | 09:57 AM
novae500's Avatar
W211
That's where I got mine. Behind the counter. With new green fluid no more whine or noise. Fluid drained out was honey brown !!
Old Feb 4, 2013 | 10:27 AM
Quadcammer's Avatar
I looked through that thread. The reservoir in my car (same m113) does not have that screen.
chf 202 is backwards compatible to 11s. either is fine
Old Feb 4, 2013 | 12:02 PM
GT-ER's Avatar
2005 E55 AMG
I have to check mine. I plan on flushing my fluid and so I should be able to see it when empty.
Old Feb 8, 2013 | 05:09 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Not necessarily. That particular fluid evaporates over time, so if the levels haven't been checked in some time and you find it low with no leaks, this is likely what happened.
11s or chf202
Old Feb 8, 2013 | 08:58 PM
GT-ER's Avatar
2005 E55 AMG
Where does it evaporate to? The system is pretty sealed.
Old Feb 8, 2013 | 09:58 PM
Probably the cap, but I haven't examined it. It's got to be vented somewhere to account for thermal expansion of the fluid. It will expand around 7% in volume from a cold morning to a spirited drive with a hot engine.
