Correct tire psi
2012 Alpina B7 xdrive
Correct tire psi
Hi, i have an '07 e63 wagon
245/40/18 - blizzaks lm-60 fronts
265/35/18 - blizzaks lm-60 rear
Inflated the front at 41psi
And rears at 46psi.
Is this ok? This is what it say on the driver sticker tire info.. For cold weather..
Any thoughts? Suggestions?
Tx
And rears at 46psi.
Tx
2011 E550 - 4Matic, 2008 ML550
According to the Bridgestone site for those tires...copied below..
What is the proper inflation for my tire?
E55 AMG 2006 Mercedes-Benz
Size Speed Rating
Front inflation (PSI)Rear inflation
(PSI)245/40R18H 32 265/35R18H 35
This information is compiled from third party sources and it's for your informational purposes only. This information is offered on an "as is" basis. Bridgestone does not warrant or make any representations regarding the use of the results or the use of this information. Consult your vehicle owner's manual for more information. This disclaimer is in addition to the sites terms and conditions.
Size Speed Rating
And yes that was for the Blizzaks
you can go here and click on the link for tire pressure -
http://www.bridgestonetire.com/tire/blizzak-lm-60
even though for me I would prob go 34-37 to not make it as squishy - but what you have seems really high.
But others should chime in too.
