OT, Anybody here worked on 2.2l S10 engines?
Not only that, but we also found a bad injector and the fuel regulator just went and blasted fuel everywhere. Sorry, but this is why I don't work on old GMs..
Why? That is literally about as easy a vehicle to work on created in modern times. Don't blame the vehicle because you took on a skill level 2 puzzle and you're still a 1. It's a cam in block, pushrod 4 cylinder with tons of room to move around it. No timing belt to relalign when you're done, you just torque the rocker arms to 22 ft lbs And throw the valve cover back on.
In regards to your fuel line, the line is bent. You need to straighten it out so that the threads are grabbing correctly when you try to turn it. Crows feet wrenches work well here on the end of a 6 " ratchet and extension. I think there's an oring on that line too, make sure you didn't trash it.
Your line isn't going in straight, seems to be leaning a bit to the right to me.
But the line is not threaded, it just slips in and seals with an o-ring and is held on with a bracket. We finally got it, then the o-ring failed, so getting a new one in tomorrow.
On vortech s10s, it is a breeze, but I just always encounter problems on the older 2.2. this would be the third one I have worked on, and everyone was a PITA.
