my 2007 e63 stays in 7th gear sometimes even when i come to a stop. bad valve body?
i did some research and i found out that on the 722.9 system it is a common issue with the valve body http://www.benzworld.org/forums/w211...e-problem.html and a bit pricey.
here are my main questions: can anyone pretty much guarantee it being a bad valve body and then i just go to my indy and have him replace the whole valve body, or should i take it to the dealer, have them diagnose it first and then prepare for rape. also can it lead to any other issues or is that all a bad valve body can do? car runs perfectly performance wise. i'm gonna talk to my indy first either way to see what he says.
thanks in advance guys
thought it was the valve body also, but it turned out to be a speed sensor code in trans module... replaced trans electronic control module/plate assembly
the job cost me $1,100 at benz dealer, parts were $516
MB Indy can diagnose the car correctly (if MB experts) but dont have the software update or valve body replacement capabilities (its need to be programmed to the car). Most honest MB Indy would not even bother diagnosing the transmission because they cant do much and would recommend you going to the dealer.
I can only guess a certain set of conditions did this.
At this point I will wait and see. 9k more and I am due for my third tranny service. I will update if any change.
