Kleemann Header Install RHD W211 E55
W211 E55 AMG
Hi guys,
I've had my E55 for about 9 months now and after detailed research am ready to start on my decided mod journey which should end with:
Kleemann K4 setup (Pulley, Headers, TB, Cams, Filters, Tune)
Quaife LSD (already done)
C63 Mufflers (already done)
550c Injectors, Fuel Rail Upgrade + Sparkies
IC Pump (already done)
Eurocharged H/E
I've read in numerous places that the Kleemann Headers need "slight modification" to fit RHD E55's.
Can anyone provide more detail on exactly what needs to be done? To the down pipe/s or main tubes? Will it create any restrictions in the pipes?
Many thanks in advance.
Eurocharged H/E
03 W211 E55
Hi
Hey fellow Melbourne member. I am sort of the same bucket as you currently in the modding process. May I ask who fitted the Quaife LSD and how do you find it?
Just so you are aware there are extractors available from www.dpe.net.au in Melton, Victoria.
Regards,
OZZYAMG
Regards,
OZZYAMG
W211 E55 AMG
Hi
Regards,
OZZYAMG
Regards,
OZZYAMG
I had Sharp Performance in South Melb fit the Quaife but was disappointed to find that they just removed the diff and sent it to some place in Sydney to do the center swap. Price was reasonable though, $1500.
Just make sure you order the right Quaife part, I have an early w211 which has the w210 diff! car ended up off the road for 3 weeks with the diff open while i had the LSD swapped from the supplier.
Either way, well worth it, I think I like my diff better than my car! puts power too the ground way better and i barely see that ESP light flash, even in the rain.
DPE (after negotiation) quoted same as Kleemann USA so i'm going to go with Kleemann.
03 W211 E55
Hi
Thanks for the heads up on me possibly having a W210 diff! May I ask do you know how can I tell if I have a W210 setup or not as I am considering the Quaife lsd unit.
Regards,
OZZYAMG
Regards,
OZZYAMG
W211 E55 AMG
I found out by counting the teeth and comparing to quaife tech drawings once diff was already open but i'm sure theres an easier way!
