--82mm throttle body question--
i already took mine off with the help of albert its real easy now just waiting to get the fab work back to install it and make sure to torque all bolts properly
You could have used a heat gun to loosen the glue on the stock tb..at this point you have to go to the stealership, I think it's like 100$
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
The "Plenum" - is it the "snout" where the TB attaches to?
If so i'd want to bore that out and use a self-made plate like in the guide linked.
So now some people say the wiring is plug and play, others say it isn't. What is true?
I bought the original MB TB.
BTW: What size TB does my CL55AMG normally have? Some say 76mm, some say 80mm ?
Ok hmmm... Is it hard to take the SC off? Any guide on that? What new gaskets do i need?
#32
SO no clear guide for that?
I guess i will check the WIS. Any other good ideas on maintenance while that thing is out?
I plan on doing a SC oil-change with JET-A oil. Should i do any bearings while its out?
#34
i already orederd the JET oil too and will change it when i pull my S/C out as well
#35
05 E55, 07 ML500
I just did my 82mm TTM TB and when the supercharger came off, low and be-hold 1 one of my bolts to the Block was Completely stripped was leaking, block had to be re-tapped.. Glad I found out.. Shout out to ACG San Diego for the GREAT work..
#37
were was that leak happening
#38
#43
^ Not exactly true.
This was the first "adapter-less" 82mm install.
https://mbworld.org/forums/w211-amg/...b-install.html
TTM sells a complete kit based on this, or they could fab the plenum/inlet for you.
