--82mm throttle body question--
Hey guys what Throttle body could be used off a different mercedes that will slap right on our supercharger snouts and that is a plug and play as well??
chime in if you have any thoughts as far as what car has it year and such so i can dig deeper and see if i can come a corss one. There is a guy down here that has a junk yard and he usually gets all kinds of benzes and i can see if he might have one for me...
thanks in advance
thanks in advance
None of the 82mm tb are plug and play. The MB ones will let you plug the tps harness in without any modification. All of the 82mm tb need to modify the sc inlet to make them work.
i dont mind about the snout work i will have an adapter that will work and bore the snout as well... my question is what car had the 82mm tb
here is a link to how to make the adapter... OEM T/B as well
https://mbworld.org/forums/w211-amg/...ttle-body.html
Received 1,488 Likes
This place is a joke.
Any of the older 550 models...most yards will sell the TB separate as they typically sell the engines as long block only with no accesories including the TB. I have already found a used 82mm TB for about $300 from a scrap yard
thanks david, yah seems the same... am deff interested into this but i am just scared if i need to have bigger injectors at this point or no?? what do you think
$400 range sounds right for a used 550 one
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Now bought myself a 82mm TB from Daimler. Will do this asap, however do i really have to disassemble the SC inlet and thus removing the SC from the car? I actually would want to avoid that.
anyone know where i can get the wire for the tb. i sold mine and couldnt take off the wire because it was glued on with the jaws of life
