HID fogs
As in which temperature of bulb? Are you going to use a projector lens so you're not blinding oncoming traffic?
90% of OE temperatures are 4300k. Stay between 4000k-5000k and you'll be happy.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
4300k is a color match for OEM. 6000k is a totally different color. Remember the fogs have a refective housing and a not a projector lense so the color of the illumination will appear a bit different.
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i went with DDM tuning kit and they were pretty straight forward install other than having to drill one hole in the back of the main headlight housing, but the fogs required no modification
https://mbworld.org/forums/w211-amg/...installed.html
i know guys have the kits that match their headlight.. would be nice if they would chime in and say what temperature bulb they bought to match.
thanks. All ordered
DDM HID Kit, 35W, H7, 4500K (Kit / Package)
Bulb Color: 4500K
Bulb Type: H7
Wattage: 35 Watt
Bulb Color: 4500K
Bulb Type: H7
Wattage: 35 Watt
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Hold on I think the fog is a 9006 not a H7
I went with Apex Cone no fault codes work great 5 years.
https://mbworld.org/forums/2657262-post3.html
Thats the point of this thread. im confident i got the correct info to make sure the fogs match my headlights..
Edit: like i said im a rookie.. i already have matched city lights.
Ok my bad, 55s have 9006-9007 they did change, so you are most likely correct.
The Apex Cone is now the DDM brand they work well with no errors.
2006 C230SS, 2007 e63, 2009 gl450, 2003 Ducati 749
U can not put hids into the e63 fog without modding it. I learned the hard way. The bulb is an h7 but it plugs into a weird base that screws into the foglight housing and that is where the connector is at. Go take a look for urself. Very ez to take off. And dont let the e55 with e63 conversions trick u. Their fog set up is different from the oem e63 setup
