Rear suspension height uneven...
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
After getting my tech to lower my car thru star, it became apparent that I had a leaky rear bladder. OK, new arnott's installed, reset, ready to pick up and go. Not so fast.
The rear is now uneven side to side. One side is about an inch higher than the other. Since the rear does not have independent adjustments, they are a bit stumped. Can someone give me some insight or point me to a thread? Everyone at the shop is getting a bit frustrated. Thanks...
I would say use a shop that knows what they're doing. There was thread on this. Something to do with cycling through raising the vehicle and changing the settings.
We have changed numerous 211 rears and never experienced this problem. BTW, there are no separate settings for each side of the 211. There lies the problem.
I think my next step is to see if we can get some help from Arnott. They have excellent customer service.
Craig, I'm about 90 minutes from your shop. I know your guys should be working on it. If you want to PM me, I'll tell you why it's happening here.
Mine did that after I changed the wheels one time. Drive it. Raise it. Lower it. See if it goes back.
I have diligently searched for any thread on this with no luck. Maybe I need some different terms....
