Serious airmatic issues. In need of some help!
https://mbworld.org/forums/5522729-post1.html
Moving on I install one of the used bags and fire the car up to see if it is all fixed and the compressor wouldn't turn on. I figure the compressor must have gave up, I pull it out and hood power and ground to it using a drill battery and it turns right on. I disconnect the power from it and then reconnect a few times and it would turn back on a few times then it wouldn't fire up anymore, at this point I ordered a new compressor off Ebay, it comes in and I install it, fire car up and again the compressor doesn't turn on. I checked the fuse in driver side panel at end of dash and it was good, I checked the big orange 40am fuse under hood and it was good, I checked the relay hitting power and ground to it with the drill battery and it clicked and also checked continuity to the other poles of it with a multimeter and it all seemed good. I pulled the relay harness plug up as far as I could out of the fuse box under the hood and I see constant power using a test light at the position that pin 30 of the relay plugs in to, I hooked the test light to power on the post with nut right by the relay and checked the positions that pins 85 and 86 go to on the plug for ground which has 2 small wires coming in the back of it and I get no ground at either of those with the car off and with engine running. I assumed the ecu must send a ground signal to those to activate the relay to shoot power over from pin 30 to the other side to pin 87 to fire up the pump. I halfway looked at the fuse under passenger footwelll area also but assume that is the fuse that sends power to the fuse box under the hood where I am seeing power at pin 30 of the relay harness plug so figure everything is good in the fuse and relay department, just not sure about the pins 85 and 86 not getting signal in the relay harness plug.
I jumped power across the relay plug from pin 30 to pin 87 position with the car off and with engine running and the compressor turns right on when I jump power but it just sits there and runs that the car does not raise, it is slammed and doesn't budge even if I run the brand new compressor for 30 seconds and I hear no leaks anywhere. I figure the compressor is creating pressure but it isn't being sent out to the 4 corners of the car due to something else going on with valves or something but no clue what to check. Only thing I can say is the electrical connector on that passenger rear bag I replaced wouldn't lock in to place but it was pushed on to the plug on the bag, not sure if that could be causing an issue with the car not wanting to raise even when the compressor has power jumped to it. But that is a whole different problem from also not having the compressor come on by itself.
Any ideas?
Any ideas?
P.S. urbamworm, love your wheels. What make are they, please?
Wheels are 20" Vossen CV7. Actually need a replacement front one since I hit a bad pothole and bent one.
Replace all air springs as I did. In my case, problem solved. If still a problem, verify/replace sensors. After that, replace compressor. After that, valve block. After that, airmatic module. After that, buzzing out every individual wire.
How in-depth do you want to go?
Also, you need to calibrate your suspension whenever you perform major work on it. Such as replacing the air springs. I've posted DIYs on this but you need a STAR/Xentry system and an inclinometer app on your cell phone to perform this. If you don't want to spend the money on the equipment, then pay the dealer. Seriously.
Best of luck to you.
