My car randomly calls SOS and nav/music shuts off!!
Old Apr 1, 2013 | 11:28 AM
E55Dimon's Avatar
E63S
Last few days my car decides to call SOS emergency call randomly.
Nav screen and music will shut off every ten min for a few seconds.
Electronic trunk closer broke few days ago, have to slam trunk two or three times da faq.
The emergency call pisses me off bigtime. It's loud and noway to end the call for five minutes.
Just as I'm loading the cv3's in the car it calls SOS again.
I have just about had it, need my music and not SOS when I'm ballin like outta control on these cv3s.
Makes a random beep sound here and there too.
Help!
Old Apr 1, 2013 | 11:35 AM
berti_00's Avatar
2016 Cls63s AMG
unplug your battery for a while and see if that helps...
Old Apr 1, 2013 | 12:11 PM
E55Dimon's Avatar
E63S
Gonna do that in a couple days. Don't like doing it taking the system out etc.
Stupid issue.
Old Apr 1, 2013 | 01:09 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Sounds like perfectly normal Mercedes electronics
Old Apr 1, 2013 | 01:13 PM
bnzuovr's Avatar
2004 W211 E55K, GL550
hey mine just started doing that to. But mine says sos inactive or some b.s cuts out for a few seconds then music is back on does it every 15 to 20 mins im gonig to try disconnecting the battery as well.
Old Apr 1, 2013 | 01:15 PM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
No fix to this Dima... Happened to my car for 2 years started weeks after I picked it up. I would possibly try removing anything connected to the SOS.
Old Apr 1, 2013 | 01:49 PM
E55Dimon's Avatar
E63S
Wtf noooooooo!!!
Old Apr 1, 2013 | 02:07 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Some say you can take the SOS out of the loop, some say you cannot without triggering an airbag light. Looks on Benzworld, there is a pretty long thread there on this subject. Also, have you ever had your voltage regulator replaced? THere was a campaign on these, and I think that may be related....
Old Apr 1, 2013 | 02:48 PM
moosejaw's Avatar
none
Dima
https://mbworld.org/forums/e-class-w...e-message.html
My buddies E350 shows up at my house on a regular basis. Every little question this car shows up......so much to the point that i labeled my residence MB of Aventura on Facebook Locations.
Anyways this came up and i researched it and this is what i found
Look it up.
Old Apr 1, 2013 | 04:28 PM
Craigo's Avatar
You can safely disable SOS/Tele via SDS without any other "electronic" or "sensor" issues/warning lights...
Old Apr 2, 2013 | 12:29 PM
E55Dimon's Avatar
E63S
Thank you. I'm gonna try to get the SOS shut off via star. Music shutting off is very annoying too.
Old Apr 3, 2013 | 08:49 AM
chawkins2001's Avatar
2006 E55 AMG
Help!
Maybe she just figured out you are getting married, and she is freaking out
Old Apr 3, 2013 | 09:33 AM
E55Dimon's Avatar
E63S
LOL. Well done!
Old Apr 3, 2013 | 09:48 PM
green1212's Avatar
2004 MERC E55
nav and radio cutting off
i didnt have the sos calling going on but when my 2005 e55 did the nav and radio or cd shut off randomly, 1 component in the fiberoptic loop was malfunctioning. weird that it was the sirius sat radio b/c i didnt even have a subscription and i never turned it on??? so when i had my issue went to mb and after about $1k, finally came to the conclusion that the sirius sat radio was inoperable. i replaced many components but that 1 trying to solve it myself and finally gave up. but whenever a component in your fiberoptic loop is/has a short or not communicating properly, this will undoubtly shut off the entire system. almost make the comand unit looks like its dead but dont buy a damn thing until you can get it someone and have them das/sas it and should be able to tell you which component is causing the cutoff. hope this helps!
Old Apr 3, 2013 | 10:04 PM
skratch77's Avatar
2005 E55
If your car is having trunk closer issues I will bet anything it cut a bunch of wires on the drivers side on the trunk hindge.
The wires get cut by the hard plastic that digs into them
Old Apr 4, 2013 | 08:40 AM
E55Dimon's Avatar
E63S
Great feedback thank you. I will be taking care of this ten days from now after vacation. Star it is and taking trunk apart, one of those annoying issues that rly shouldn't have happened.
Old Apr 4, 2013 | 10:26 AM
green1212's Avatar
2004 MERC E55
definitely agree!
yeah i hope its not the trunk thing cutting wires. man the brain of the whole operation called the agw (audio gatewate module) rests in the trunk on the drivers side and skatch is right, there are tons of wires back on that side with the nav, and agw, which all the wires from the stereo, sirius, bluetooth, phone, etc any and all communications in regards to radio/phone/hands free voice etc all connects to this module. yeah i replaced it too thinking it had overheated but again, it was just 1 simple component. dont let them just tell you that you need a new agw either, b/c that is the first thing they will tell you. tell them to put a "new" one in and if all checks out on your test drive then and only then fork out $1k for the labor and parts fee for just that 1 component. that module alone will take over an hour to get to, its stuck back inside this little corner, pita!! why merc do things like this!! anyway, you should be able to get to the culprit soon enough. have a nice vacation and good luck with the fix.
Old Apr 4, 2013 | 10:34 AM
skratch77's Avatar
2005 E55
one day I tried closing the trunk and it would not close on its own and then I got a wired sos tele mess on the front display,I took apart the left side trunk hindge and the stupid way mb designed it has the hard plastic digging right into like 40 wires and like 10 of them were cut and even a few completely cut,I matched them up and twisted them all back together and added some padding to stop it from happening again and it fixed my issues with the trunk and sos system.
Old Apr 5, 2013 | 05:42 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
My car just started showing "SOS malfunction visit workshop" or something like that. Nothing happens though except that showing in the center display and I just hit the arrow on wheel to get out of it. It did it like 4 times the past 2 days.
Old Apr 5, 2013 | 06:13 PM
Ronan Mc Cabe's Avatar
Gone but not Forgotten 2006 E55 Renntech
Mine does the same and it seems to do this after it rains heavily.
Rains > Get the SOS Malfunction visit workshop > few days later (no rain) the warning goes away.
Nothing in my trunk appears wet or damp.
Old Apr 6, 2013 | 08:58 AM
jawdoc's Avatar
2005 E55 AMG
My cruise control randomly shuts off. Turn the car off and it works for about 15 min then quits.
Any ideas?????
Old Apr 6, 2013 | 09:06 AM
skratch77's Avatar
2005 E55
Take apart the plastic on the left hindge in the trunk while its opened.the plastic pops off and you will see near the end that when the trunk closes it crimps a crap load of wires.
Now when it rains at that same exact spot water will pass threw and channel down threw the trunk and out from under the license plate area.
I'll bet you have some cut up wires on there my friend.
Old Apr 6, 2013 | 01:41 PM
urbamworm's Avatar
It was rainy the other day when it did this, can't remember if it was during that time or not. It is sunny now and it hasn't done it again yet.
Old Apr 6, 2013 | 03:33 PM
Thanks for the info, will check it out and post update if I get it fixed.
Old Apr 7, 2013 | 05:40 PM
jarvis210's Avatar
1998 C43 w/ N/A 5.4l swap
your teleaid module is going out and needs to be replaced and or coded out via das and electtrically disconnected or it can cause this. i have seen this multiple times
