Can I fit the 82mm throttle body and do pin swap on standard tune
Old Apr 7, 2013 | 07:47 PM
OZZYAMG's Avatar
03 W211 E55
Hi
Does anybody know if I can install the Eurocharged 82mm throttle body and do the pin swap as per Eurocharged's instructions and still drive the car home from the mechanics and to the local shops everyday slowly using the standard tune? I only ask as I am due to fit the throttle body and injectors tomorrow and doesn't look like my tune will be ready to download into my car.
Regards,
OZZYAMG
Old Apr 7, 2013 | 08:46 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
If the electronics were a MAF system, I'd say no problem. In this case, you might not want to.
Old Apr 7, 2013 | 09:25 PM
OZZYAMG's Avatar
03 W211 E55
Hi
I honestly thought it would be ok as long as I did not accelerate too hard and stayed off boost all the time?
Regards,
OZZYAMG
Old Apr 8, 2013 | 01:32 AM
Well, the calibration will be less off at lower loads/throttle position and the O2 sensors will have some correction as long as you stay in closed loop. YMMV
Old Apr 8, 2013 | 10:06 AM
pimpjuice's Avatar
2003 E55 AMG
if you are worried about boost...take off the SC belt and drive gently home
Old Apr 8, 2013 | 11:15 AM
ahmad0658's Avatar
Brabus K8 E55 05
Won't be an issue at all, just stay away from high boost for the engine safety.
