E63 Regret
Old May 1, 2013 | 09:22 PM
ScottAlexander's Avatar
07 E63
E63 Regret
Bought an 07 E63 with 50K. Physical condition is superb. I can't believe all of the warning messages and bugs I'm having;
1. ESP is inoperative
2. Key battery is low (I just replaced it a week ago)
3. Get's stuck in first and won't shift out
An $85K sticker car with 50K miles should not be having these issues. PERIOD. What is going on? While I love the car and it's performance, the quality is very disappointing. What else should I expect to go wrong? Starting to question whether I made a good decision.
Thought?
Old May 1, 2013 | 09:40 PM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Have you tried the basic task of disconnecting the battery? These cars are as computerized as it gets. A possible tcu reset may help.
Old May 1, 2013 | 09:48 PM
E55Greasemonkey's Avatar
This place is a joke.
Thought?
1. Probably a faulty steering column module
2. You have a faulty key- there seems to have been a bad batch
3. Probably a faulty trans valve body or electric plate
All common E63 issues, along with broken/stretched head bolts on the engine. Do you have an extended warranty? If not this may be the time to
look into one.
Other than these issues, the rest of the car is pretty solid. Mercedes builds very complex vehicles..they ride and drive like nothing else, but the downside is more things to go wrong.
Old May 1, 2013 | 10:35 PM
FromM3toAMG's Avatar
07 E63
should have had a buyers inspection done. theses issues didnt just suddenly pop up once you signed on the dotted line.
Old May 1, 2013 | 10:41 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
NJ submarine........................?
Old May 1, 2013 | 10:57 PM
We just saw our first "sandy" car here...They are heading south
Old May 1, 2013 | 11:03 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Yes for the ESP module, replaced mine already at purchase
Key batteries, possible 1 weak battery in fob, tried duracell in one fob have I think Philips cheapies in the other fob. Once in a while will get key batteries low but the car doors always open and the car starts with key less go.
Does the trans normally start in 2nd when just placing the shifter in Drive and operate normally, I am thinking issue is with the paddles , possibly?? How does it shift using the shifter to change through the gears?
Have read a lot of info on the bolt issues seems like the C63 has a lot more failures, not sure if it the way the guys are flogging the cars or just unlucky??
Have two cars E63 and a CLK63 both 07 no issues what so ever, sorry had to replace the AC compressor on the E took 4 hours DIY, seized for some reason after sitting idle for six weeks but then again the cars are not beaten, both ran non stop for 1200 miles no oil used and no coolant loss.
These cars never fail to put a smile on my face hopefully that will continue.
Old May 1, 2013 | 11:08 PM
E63//AMG's Avatar
W211 E63
Thought?
You bought a USED car. Obviously you don't know the history or condition of the car. I wouldn't look to put the blame on MB but instead on the buyer. Sorry you are having issues, but a pre purchase inspection would have been wise.
The transporters from NJ show up at auction in Davie FL full of cars that are too clean. And leave full of cars that need to be cleaned.
To the OP tell us more, you blame the quality of the car, did you buy it from a Mercedes Benz dealer with an extended warranty?
CarFaux
Old May 2, 2013 | 12:12 AM
IndiumGreyE63's Avatar
2008 Mercedes Benz E63 AMG, 2017 Porsche Macan S
Sorry to hear about all of your problems. Mine has been rock solid for the past 5+ years of ownership. Still drives like a dream, and turns a lot of heads.
Hope you get things sorted out soon.
Old May 2, 2013 | 07:38 AM
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
CarFaux
Wow.... I can say first hand,there where tons of flood cars that lined up the city streets. Most of high end flood cars were in lower Manhattan.
Old May 2, 2013 | 08:17 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Wouldnt they show up as a salvage flood title?
Old May 2, 2013 | 08:48 AM
thumper823's Avatar
04 E55
YES
Old May 2, 2013 | 09:37 AM
JACK PRESTON's Avatar
E55, G55, 1987 Kasten Wagen (2 door LWB G WAGON) 1991 e30 vert with euro M3 motor
+ 1
Old May 2, 2013 | 11:54 AM
07 E63
Original poster here. Thanks for the feedback. To clarify a few things though; Yes, I realize it's a used car. I do have the service records. No major issues. It' a cali car, so not a submarine.
My point is if I am the original owner or not, I'm surprised a car like this can have this many bugs. I am beginning to learn how complex they are (2 batteries?!?!?). Naturally, it has more things to break so I get that.
I love the car and plan to stick with it. Flexing my right foot seems to make all of those other concerns go away :-)
Old May 2, 2013 | 12:00 PM
novae500's Avatar
W211
Glad to see you are enjoying the car. Since ownership, i've had things fail and needed replacement and swear to sell the car. But when i get in and stomp the gas and see how it performs, i see why i purchased it.
Old May 2, 2013 | 12:12 PM
Critter's Avatar
What do you mean by 2 batteries??
Old May 2, 2013 | 12:25 PM
Shifter's Avatar
E55, SL63, ML550
I wouldnt call those issues " so many bugs"
Fairly simple fixes common to the platform. Any other German car is the same way.
Old May 2, 2013 | 12:28 PM
Critter's Avatar
Scott, Your E63 has only 1 battery and it is in the trunk, under the mat on the passenger side. If it is the original battery then a replacement would not be a waste of money. Look for a dating on the battery to be sure, these cars like good constant voltage and a weak or old battery will put a strain on the altenator as well as other components which will lead to more pop ups on the dash. Stay strong and enjoy, the 55 guys are showing some envy as they wish they had one too. Bring on the h8ters of the 63, not everyone buys a perfect car oh did we say heat soak, never experienced this in a 63! Oh yes get the ESP fixed ASAP, you need it.
Old May 2, 2013 | 12:31 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
none of those are serious issues IMO. they are a bit pricey though. more than likely, your conductor plate is bad and expect to spend about $1,400 at the dealer with parts and labor. they do the tranny service at the same time they replace it usually (at least they did for me). as for the ESP, just have them do an hour or two diagnostic while you're at it.
Old May 2, 2013 | 01:42 PM
jaedee's Avatar
w205 C63s, w212 E63,w219CLS500-SOLD! w211 E63, 2006 E60 M5 (KABOOM!)
Main battery is in the trunk. (no pic required) Auxillary battery is in the engine compartment, passenger side under cowling, near the firewall. (arrow is pointing to the aux battery relay that I used to show another board memeber the location.)
Old May 2, 2013 | 02:07 PM
ehaze's Avatar
e63
CarFaux
Can't trust it.
Old May 2, 2013 | 02:15 PM
63 doesn't have SBC, therefore no aux battery
Old May 2, 2013 | 09:01 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
You are right us E55 guys are so envious of the mighty E63
Fast forward to 2min 30sec to see my stock E55 with only a tune against a E63.
The E63 is a great car, but will have a tough time keeping up with an E55 once any mods are added.
The fastest W211 E63 is running 11.95 in the quarter mile on dragtimes, there are a number of E55s in the low 10's at this point.
Old May 2, 2013 | 10:54 PM
forcefed4door's Avatar
05 E55, 06 Audi S4
same goes for the b5 s4 vs b6/b7... why the manufactures move backwards at times is strange.
