Jacking one side at a time
Old Aug 26, 2003 | 10:37 PM
tjcMBE55AMG's Avatar
2002 MB E55 AMG
Getting ready to paint the brake calipers. Looks like the only way I'll make the pot life / dry time is to do both calipers on each side at the same time.
Any suggestions as to a safe way to do this? Jackstands?
Thanks in advance
TJC
Old Aug 26, 2003 | 10:40 PM
E55AMG99's Avatar
1951 Caterpiller D6
Re: Jacking one side at a time
Thanks in advance
TJC
Jackstands are a must. I wouldn't rely on the factory jack either if you plan on doing this on your smooth garage floor. My E55 dropped on the rear hub when the jack slid out from under the car. Yes, the e-brake was on tight.
Old Aug 27, 2003 | 01:51 PM
dd_kota's Avatar
02 c32, 03 e55
what color are you painting them? are you going to repaint the amg on them?
Old Aug 27, 2003 | 03:11 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
dd_kota, tjcMBE55AMG has the previous E55 and the AMG logo is not prominent like the W211 E55. The rear brake does not have any logo on W210.
tjcMBE55AMG, use 4 jack stands all around. Setup and cleaning is the most difficult part. Are you using the 2 part paint type with hardener? If so, the paint will be unusable/unpaintable after 6 hours. Here is mine:
Old Sep 2, 2003 | 10:33 PM
2002 MB E55 AMG
Jacking
Kev - Same car, (same color???). I'm going to do the calipers red. Figure I'd have time to do one side at a time. I don't like the idea of 4 jack stands though. Isn't that a little risky?
If I do use 4 jack stands, what are the acceptable support points?
TJC
PS - Am I stupid or does your axle look lower to the ground than it would with a wheel on?
Old Sep 3, 2003 | 09:07 AM
E55 KEV's Avatar
Veteran: Air Force
Re: Jacking
TJC
4 jack stands are the safest way to go. Only using a jack is dangerous.
At my local dealer they had a car on stands and they used the 4 round rubber pieces under the side sills, but that is the point I place my floor jack. There are few good chassis points to use jack stands you have to get up under there to see.
Axle height - optical illusion for you.
Old Sep 3, 2003 | 09:56 AM
E55AMG99's Avatar
1951 Caterpiller D6
Re: Jacking
TJC
4 is better than 2 because you can get the car level but if you are careful, 2 can work well. The axle is lower to the ground when jacking the car from the frame. The suspension is in full extension.
