Trubole Throthle 82 MM MB
Old May 4, 2013 | 04:27 PM
hasse_231's Avatar
c32 amg evosport stage 2
Hello..
I do have an 55 AMG 2006.
Today i installed an MB Throttle from an CLS 550 82 mm
After flashing the car i do have a problem with the throttle, its wide open when ignition on ? Its 100 % open at start already.
The car do complain that the ESP Is defect and a few fault codes for the throttle. Its the same fault the throttle.
Also you cant drive or push the gas its like missfiring in the intake.
Do i have to Switch 1 and 4 and 5 and 6 ?? Or do some one have any idea ?
The throttle is a273 141 03 25 From mercedes and the Cable a1131500028.
Please some one who can help.
Best regards Hasse
Old May 4, 2013 | 04:56 PM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
Remove cable 1131500028, this cable has the pins reversed. Just use the plug straight from the car.
Old May 4, 2013 | 05:03 PM
berti_00's Avatar
2016 Cls63s AMG
yes you have the throttle cables mixed up..... the throttle body under the snout is pluged into your 82mm so you have to switch that one to the other cable and should be fine
Old May 4, 2013 | 05:10 PM
mertd93's Avatar
Looks like he bought an extension cable part # 1131500028 and used it to extend the tb cable, it's def not necessary. I don't think he has the cables mixed up with the bypass if that's what you're saying.
Old May 4, 2013 | 05:23 PM
berti_00's Avatar
2016 Cls63s AMG
i dont get why he needs an extended cable??? when the cables are already there. i just did this and my car is as smooth as could be even better than before and love the 82mm
Old May 4, 2013 | 05:28 PM
cm60k's Avatar
He may got a leak between the TB & snout, or one of the cable pins not connected well.....??
ZAYED,,
Old May 4, 2013 | 06:47 PM
mertd93's Avatar
Well that cable is perfect if you use the 78mm tb since the pins are swapped already, so it's plug & play.
Old May 5, 2013 | 12:47 AM
hasse_231's Avatar
Thanks for all the answers.
You cant connect the cabels wrong, Meaning the lower tb to the upper one.
The connectors is diffrent.
But as some one did say i maybe should try with out the extention cable ?
I will try it today. If so you guys have saved my weekend.
the time here 7 hours Before you
Old Aug 18, 2021 | 12:01 AM
E55Amg314's Avatar
2005 E55 AMG
Having the same issue with my 2005 e55 Amg what did you figure out to get it to work?
Old Aug 18, 2021 | 12:02 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Despite the old post above, you definitely can connect the bypass TB cable to the main TB, they are the same connector, so make sure yours isn't swapped around. No pin switching needed with the 550 MB TB, it's plug and play.
If that isn't your issue, I'd try a full battery unplug reset, sometimes if these connectors are removed when powered up it can cause all sorts of odd issues like this, an ECM reset would hopefully solve that if so. Good luck!
