EC Supercharger pulley failure... :(
Old 05-07-2013, 12:47 AM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
Now before things get messy, I am contacting EC tonight via email and phone tomorrow about this issue. I called earlier today, but now that I got a better look, this is a much more serious problem. But as of now, I have *NO* problems with EC, heh.
I turned my car on today and was about to drive out. As soon as I put the car in gear, I hear a god awful grinding noise. It sounded a lot like a bad bearing, so I shut the car off and checked it out. It initially looked like it was a bad bearing and I informed EC as such.
I was incredibly wrong.
The arms that hold the SC plate cracked! One is complete cracked apart, and the other is on it's way out. The plate had slapped onto the clutch on a small spot and apparently was grinding for those 15-20 seconds the car was on. I turned it off quick like I said, so I think the SC is fine. But the pulley definitely failed.
Bought the pulley brand new back in November. I do like to do pulls on my car, but I definitely take care of my car. Either way, this should be something manageable on EC's side, right? Obviously, I'm not driving the car at all until this is fixed.
Attached Thumbnails EC Supercharger pulley failure... :(-img_20130506_210239_012.jpg   EC Supercharger pulley failure... :(-img_20130506_210253_543.jpg   EC Supercharger pulley failure... :(-img_20130506_210323_906.jpg   EC Supercharger pulley failure... :(-img_20130506_210339_653.jpg
Old 05-07-2013, 12:53 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Looks like an easy enough fix, glad you caught it in time. How was the engagement on it when it was right? What I mean is, how did you have it shimmed?
Old 05-07-2013, 01:00 AM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
To be fair this is not a "Eurocharged" supercharger pulley, they sell the Shardul pulley and I could be wrong here but think it is made by ASP. Either way, I am sure it will be swapped no problem. Many of these out there running well, hopefully just an isolated case.
Old 05-07-2013, 01:01 AM
I checked and made sure it was spaced to factory specs if that's your question. .5 mm or something like that. I needed all the shims.
When it was first done, it worked absolutely fine. No problems what so ever. Engaged great. Today was the first day it goofed up. And from what it sounded like, it cracked just today.
Old 05-07-2013, 01:36 AM
03'55AMG's Avatar
AMG
Maybe just a one out of a million flaw. I am sure they will step up and replace it without a problem. They wouldn't be where they are today without the great track record for customer service they have.
Unless of course the install was flawed or something else caused it to happen.
Old 05-07-2013, 01:39 AM
Then I guess it'll be cool. Nothing else on the car is wrong or anything. Just is irritating I can't drive my car. :/
Old 05-07-2013, 01:51 AM
03'55AMG's Avatar
AMG
I can understand that.. I hate when I can't drive the E55 due to weather, maintenance, etc.
Old 05-07-2013, 02:20 AM
edmond1129's Avatar
E55
Sadly, I am doing my oil change just now and found out the same problem too. Now I am changing my original factory one back and will try to find some one to make that spring
Old 05-07-2013, 02:58 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Do either of you also have larger crank pulleys? Other power mods?
Old 05-07-2013, 02:59 AM
03'55AMG's Avatar
AMG
Wow 2 pulleys within 24 hours? When did you both purchase them? Maybe there's a flawed batch?
Old 05-07-2013, 04:04 AM
berti_00's Avatar
2016 Cls63s AMG
I never really made a big deal about it but mine happened too... it was the first batch, when they were peoduced but got new one replaced within a day
Old 05-07-2013, 05:26 AM
edmond1129's Avatar
E55
I don't have larger crank pulley, all I have just headers, tune, with some exhaust mod and cooling
Old 05-07-2013, 06:13 AM
03'55AMG's Avatar
AMG
Koru_Kinshi, and Edmond1129, when did you both get your pullies? If its around when Berti did, it must just be a flawed first batch. I would NEVER expect EC or Shardul selling things they didn't think would last forever
Old 05-07-2013, 06:50 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Sometimes the springs crack. Contact your vendor and they should replace it at NC
Old 05-07-2013, 07:06 AM
forcefed4door's Avatar
05 E55, 06 Audi S4
ain't that some bs... hopefully this doesn't eventually happen to the majority.
Old 05-07-2013, 07:56 AM
Forrest Gump 9's Avatar
shrimp boat
Shardul will take care of it
Old 05-07-2013, 09:02 AM
novae500's Avatar
W211
Hope these are isolated occurrences and last at least what the OEM s/c pulley did for me,69,000 miles before i switched over to the new smaller s/c pulley.
Old 05-07-2013, 09:28 AM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
This isn't Shardul's problem lol.
Even if EC buys from Shardul, the customer should always go back to the vendor.
Old 05-07-2013, 09:40 AM
desant89's Avatar
2007 S550
I just had a 168 pulley, and this SC pulley installed....So it sounds like one failure was obvious to the driver, and the other just happened to stumble across it during an oil change. Guess I better check it every once in a while.
Old 05-07-2013, 10:49 AM
bnzuovr's Avatar
2004 W211 E55K, GL550
ohhh boy i hope mine will be okay so far so good. Modding is becoming a scary thing to do these days but in all honesty i rather have a s/c pulley go bad vs a damaged crank shaft.
Old 05-07-2013, 11:12 AM
GregMB's Avatar
To any of the guys who saw failures.... How many miles were on the new pulley when the failure occurred?
1000 miles? 5000 miles?.... More?
It would be interesting to see if there was any correlation to mileage or not.
-G
Old 05-07-2013, 11:13 AM
novae500's Avatar
W211
mileage and how many hard runs on a daily/weekly basis as well.
Old 05-07-2013, 11:14 AM
RedBullJnky's Avatar
you to Hate
Eurocharged will take care of you!
Old 05-07-2013, 11:23 AM
desant89's Avatar
2007 S550
If I knew what I know now, I would have went with 180 crank and left the stock SC pulley on. There seems to be no advantage to doing it with a SC pulley and smaller crank. I actually seen another 55 car get dyno'd ad the same exact time. Bpth were done by the same installer. Difference was he had a 180 and stock SC pulley vs my 168 and SC pulley. HP was 2 les than me. I'm at 503.69, and he was at 501. My HP jumped up faster, but also dropped off faster where his was more linear. Later in the RPM range he had a huge torque advantage on me (like 40) although we both had roughly the same peak torque (537+539).
So given this, and that there have been some other failures (aside from these), I just think it's better to simply go with a larger crank pulley and leave the SC pulley alone. Just my .02
Again, I am no mechanic, but just not seeing the advantage here. The fastest cars, and even vendor cars seem to not even be running the SC pulley.
Old 05-07-2013, 11:50 AM
The advantage is not having to screw with the crank pulley at all, since it seems like one out of three falls off.
Quick Reply: EC Supercharger pulley failure... :(
