How long on 82MM TB Install
Just wonder for those that have done it how long to they estimate it will take?
I have full SDS print out on steps.
id give yourself 4 hours. should be plenty of time if you have a decent set of tools. biggest thing is the supercharger removal to unbolt the snout. i have the full set up for sale if you are interested.. https://mbworld.org/forums/engine-pe...elbow-55k.html
i also have looped rail and TTM injectors.. if you plan to go nuts! lol
Dirt Scooters
You can have the s/c off in 15-20 minutes. I cut a couple rods to use as guides to put the s/c back on without damaging gaskets and makes it pretty easy. Shouldn't take you more than 2 hours taking your time.
Next time i will definitely make guides for the s/c. Good call!
