s/c bolt need help
Old May 16, 2013 | 08:50 PM
jonnyc's Avatar
e55
s/c bolt need help
so im trying to change out the pulley and I can not get the bolt loose.i was going to follow the eurocharged instructions but mine is different than what they show.i don't have the same stud they used for the pry bar and my bolt head is 15/16 not 12mm.they say to torque it to 20nm which is about 15 ft/lb but this bolt is a lot tighter than that.i don't have enough room between the bolt and radiator fans to get a socket and impact gun on it.i can't get the clutch housing to stop turning when trying to loosen the bolt.i've tried the prybar method and a strap wrench and I just can't keep it from turning.
anyone have any suggestions?
Old May 16, 2013 | 09:02 PM
jonnyc's Avatar
e55
in this pic you can see the stud im trying to use to pry against.its in about the 10:00 position
in this pic it shows my shortest socket on the bolt and I barely have room for one finger between the socket and the fan
Old May 16, 2013 | 09:23 PM
tbradley70's Avatar
aviator
I did mine a few weeks ago. I lifted the fan shroud up enough to get an impact gun on there. I also heated the bolt head with a torch for about 45 seconds. That combo with a strap wrench on the clutch housing worked for me. Some guys jack up the whole engine to get an impact gun on.
Old May 16, 2013 | 09:50 PM
O-55's Avatar
2005 E55, 2009 VW GLI
The instructions you received are prob for the 32Ks, not the 55Ks.
I performed the swap by taking out the fan shroud and using some air power. I also used a
1 5/8 socket to help tap the new pulley on. MB recommends torquing the bolt to 60nm, approx 44 foot pounds, on our m113s. Be sure you use some loctite 243 on the bolt and verify the gap between the pulley and the magnetic clutch is between .35mm and .45mm.
Good luck!
-Oscar
Old May 16, 2013 | 09:53 PM
2319's Avatar
2005 E55
Oil filter strap wrench. 24mm long reach wrench and break that bolt loose and break your back at the same time. Its hard but you can do it. Your dowels will most likely break in the process. No worries. See the dowel post. Hope that helps.
Old May 16, 2013 | 10:01 PM
jonnyc's Avatar
e55
well I've got the fan shroud up enough to get a socket and short extension.impact gun is having a hard time breaking it loose.
just to make sure,this is a standard thread right,not reverse?i'd feel pretty stupid if i'm trying to loosen it and its actually tightening it.
Old May 16, 2013 | 10:03 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
Counter-clockwise to loosen and an impact works great.
Old May 16, 2013 | 10:07 PM
2319's Avatar
2005 E55
Yes turn the bolt to the left if you are standing in front of the car.
Old May 16, 2013 | 10:09 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
I used an old serpentine belt and a c clamp and a large oil filter wrench
Old May 16, 2013 | 10:11 PM
jonnyc's Avatar
e55
thanks.i'll just keep heating it on hitting it with the impact until it comes loose.
my crank pulley on my vette was easier to get off than this and it torques to 210#
Old May 16, 2013 | 10:15 PM
2319's Avatar
2005 E55
Do you have a plumbing torch?
Old May 16, 2013 | 10:58 PM
jonnyc's Avatar
e55
yeah that's what I was using.
finally came off.i switched from a short 15/16 impact socket and 6" extension to a long 24mm impact socket and 3" extension and it came right off.
I installed the new one with just the factory shim and my .030" feeler gauge slides in with just a little play.i'm guessing im at .032" clearance.everything turns without rubbing.
had one little mishap,i cracked a piece of plastic off the top of the fan shroud when I was lifting it up to slide the socket in.im hoping the metal cover plate will hide it.
thanks for the help guys.took a lot longer than I was expecting.
Old May 17, 2013 | 12:41 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Extensions eat up a ton of the torque the impact gun has due to twisting the extension rather then transferring the blow to the bolt. Shorter is always better, or a stronger built extension. Or just grab a good ratchet or breaker bar and steal the handle off a big jack and you'll break anything loose.
Old May 17, 2013 | 01:36 AM
MAN55LE's Avatar
04 E55 AMG
loosened the motor mounts, jacked it up, zap impact 24mm, stock shims, teflon, and zip back togetherWOW entirely different car with sc pulley and belt wrap kit
