self inflicted battery issues...
Is it possible to jump the battery?
is it possible to take it out and charge?
can i just buy a new battery and install it myself or will the electronics and stuff go haywire..??thx for the help guys..
Once you have the battery working/new one installed. Start car and reset the window/sunroof. Pull up on the window button for each one and a bit more until you hear a click. Then the window has been reset to go down with one push of the button. Do similar for sunroof, but push forward until click or pull down until click. Cant remember 100%. That way sunroof will open with just one push of the button.
just to ad one thing though. Do not have the key in the ignition while doing anything. Jumping, charging, etc. hook everything up then insert the key. It prevents damage to control units from voltage spikes. id appreaciate any advice, is there any way to tell if I lost the tune?
