Lightweight beehive valve springs for your M113K Mercedes
Where are you at with yours Brendan ?
Look at it another way...What if all we had to do was remover our retainer that had a weight of 1lb per spring to a retainer that is only 18 grams ? That valve just became very light so to speak and needs much less spring pressure to control.
Also was there eventually a solution to the collets being not quite right?
So it will be late 1st Qtr 2021, early second for actually driving the car. ( Still need to find out if VRP is actually thinking its a joke that I don't have a pulley for a year now - I can just make one, but its so frustrating with these aftermarket monkeys. Just because you have access to CNC doesn't make you an engineer, or really, a good business owner).
Maybe wear a back brace if the engine is in the car with you doing this.
Just finished the x pipe I wanted to do and it came out great and should free up some power. {Trying to do all the "on the back on cold concrete } work now before it gets real cold. LOL
Sent inter cooler out to be coated for heat reduction like the Nascar guys do and increasing the ice tank lines from 3/4" to 7/8" for a little more flow.
3.06 gears will be the long haul project for the winter after the springs go in. Real hard to find selective pinion race shims for setting up the gears. Been busy !! LOL
Also Brenden, I would start hammering VRP big time. There is no excuse for that.
On a side note, I thought I'd design up a new valve spring seat that retains the same wall thickness (1mm) as the original seat but will also have an inner support like the top retainer now that we only have one spring. Would anyone be interested in a set? Only offering it up to fellow enthusiasts as it gets cheaper if I order more than one set, especially with post machine hardenning that is done per batch.
(Chris, I'll send a set over as soon as I'm done making them as a token of appreciation for your input. I'll PM you for address closer to the date).
I start mine Monday morning.
See how it will jam itself to the top and will have no where to go ?
Actually in the picture the keeper is sitting low right now and will slide up more.
Spring seats sound good that your looking to make as it was a real pain in the *** to grind 24 cups to fit the Bee Hive springs !!
Also you will not need an inner part to center the spring. As long as it's in the cup it will go no where and not walk around.
Only thikning of making the inner part as it will add no cost to the product itself. Will be just a 0.1" tall step like the top retainer, nothing major.
