What level(psi) boost are big mod guys normally seeing?
I see a lot of people discussing IATS and making suggestions, but I never see any data logs. If any of you guys have data logs from 60-130, post them up. I'd like to see what you guys are seeing.
I don't see speed on this run, but I assume it was 1/4 mile or better.. and 167F at the top of a quarter mile is about as good as you are going to get without an ice tank, KC or Meth.
SO POST YOUR DATA LOGS ALREADY!!!
the other thing you can do is switch some hoses around... I think my IAT at 130MPH here was around 79F (75F ambient)...
I use a separate one through the obd for iats and yes I do have the kc however you guys had 64* the other night and his iats seem high for that Amb temp
Back on subject, my max boot is 15.5 (190 lower / Stock Upper)
Craig is right, except you can also switch some hose around....
You can see the ecu dumping fuel to cool it down further, and timing been pulled but that will be corrected with meth. I would do meth first before a trunk tank if you don't frequent tracks much and like highway runs.
