Back up camera to the nav screen DIY
Old Jun 29, 2013 | 05:19 PM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
Originally Posted by jonkean
I used a vin for a 2009 W211 with Comand. Had to launch DAS manually and enter the vin, then it recognized the head unit. Your version of Star might be too new, as they removed the developer menu on later versions.
I used a friends older version star developer and it showed the development data menu, I will post pictures later, anyway I was able to set rear view camera to "installed" and comfort telephony to "activated".
So I now have a working rear back up camera. Thanks Jonkean!!
Old Jun 29, 2013 | 06:40 PM
JoeNobody's Avatar
Mercedes
Sweet! Which backup camera did you install? I looked into adding one, but couldn't find any that install without drilling holes. Since I already have Parktronic I abandoned pursuing it further.
Old Jun 29, 2013 | 07:01 PM
TonyGia's Avatar
W211 P030 E63 AMG // W204 C63 Coupe
Very interested as to how this will work! Can any COMAND be retrofitted with this option?
Old Feb 23, 2014 | 10:35 PM
gtr886's Avatar
E63 W211 08, C32 W203 02
Thumbs up Update!
I got fed up with the ******* people. Im not even sure if they are even interested in your business or not. anyway, here is the update with my back up camera!
I installed a BoYO VTL375HD and a Wifi camera transmitter. (http://www.4ucam.com/iphone-android-...up-Camera.html)
You can basically use your iPhone or android phone as backup camera screen.
I have to say this works perfectly! I just place my phone on my ash tray when I reverse. It fits perfectly and I get constant video feed.
You can actually purchase the 12V adapter for the back instead of tapping into any wires.
Old Feb 23, 2014 | 11:18 PM
OZZYAMG's Avatar
03 W211 E55
Hi
Where in the trunk was the 12 volt plug? Is the 12volt at the plug switched with the car accessories or does it go on only when the car is in reverse?
I wonder where I can buy the 12volt plug so I can utilise this power outlet for a reversing camera.
Regards,
OZZYAMG
Old Feb 24, 2014 | 12:19 AM
gtr886's Avatar
Originally Posted by OZZYAMG
Hi
Regards,
OZZYAMG
I have a 12V plug in my trunk. Maybe it's for the E63 only. If you don't have the 12V plug. Just buy the unit and have someone hot wire for constant power. You do not want to connect the transmitter for reverse power only. As the WIFI start up take 3 seconds. I just have the transmitter with constant power so that I can get instant video feed.
Old Feb 24, 2014 | 05:05 PM
  #32
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
You can tap into the reversing lights if needed so it powers only when you reverse. Unless you want to watch the looks on peoples faces as you blow past them
Old Feb 24, 2014 | 05:45 PM
  #33
gtr886's Avatar
You can do that to the camera but connect the transmitter to a constant power line. The transmitter takes 3 sec to establish the wifi signal.
Old Feb 24, 2014 | 06:31 PM
  #34
OZZYAMG's Avatar
03 W211 E55
Hi
I am about to purchase one of these:
http://www.ebay.co.uk/itm/Veyron-VC-...-/280920841044
I will install it into the existing space where one of my number plate lights are and run the power so it switched on with the reverse lights so it will only power up when my car is in reverse. I will then add the video input to the spare rca yellow input I already have in my trunk. My car is an Australian model and has 2 spare a/v inputs on the trunk mounted tv tuner (yellow/red/white) to allow for Aux 1 and Aux 2 to the front Command video screen. All I will need to do when reversing is select "VIDEO" and "AUX 1" from my head unit and the reverse camera should display on my factory screen.
Wish me luck!
Regards,
OZZYAMG
Old Jan 2, 2015 | 01:29 PM
  #35
W211_350WagoN's Avatar
S211 E350 wagon, w211 e550 4matic, w210 2001 e320, 2023 glb250, 2013 Audi q7
Hey mert, I set the rear view camera to installed, should I get a blank screen if no camera is installed?
Old Jan 3, 2015 | 07:39 AM
  #36
mertd93's Avatar
Yes it should be a blank/dark screen until you connect a camera and at the top of the screen it should say check surroundings when you put the car in reverse.
Old Jan 3, 2015 | 08:31 AM
  #37
£ C43 £ AMG £'s Avatar
E55K AMG
Old Jan 3, 2015 | 08:45 AM
  #38
E55K AMG
Hi
Wish me luck!
Regards,
OZZYAMG
tried that ebay camera, when installed it points down to the ground instead of straight
Old Jan 3, 2015 | 12:40 PM
  #39
Well I guess this guy didn't set it correct because I don't have a blank screen. I seen him set it that's the weird thing. Is there a certain way to enable it?
Old Jan 3, 2015 | 05:15 PM
  #40
turbo97se's Avatar
I bought one of these:
http://www.ebay.com/itm/Black-Waterproof-Car-Rear-View-Reverse-Backup-CMOS-Camera-170-Wide-Angle-SH-/380887532578?pt=US_Rear_View_Monitors_Cams_Kits&hash=item58aeaa8422
Cheap and worked really well. It means drilling a hole in the trunk iid unfortunately but looks pretty good when installed and quality is decent. Just need to make sure that you drill in the right place ... not too close to the rear handle mounting bolts. I drilled mine too close at first but managed to fix it.
Hi
Wish me luck!
Regards,
OZZYAMG
Old Jan 3, 2015 | 06:41 PM
  #41
OZZYAMG's Avatar
03 W211 E55
Hi
I just went out and checked on the actual direction of my reverse camera.
I can see the house across the street from me, so I believe that my camera is most certainly positioned correctly.
Maybe the manufacturer had revised some changes and I have a newer model?
Regards,
OZZYAMG
Old Jan 3, 2015 | 10:04 PM
  #42
Coding
Anyone can tell me the steps to enabling my reverse camera, does it need to be in reverse or any steps to take when enabling in developer menu?
Thanks in advance
Old Jan 3, 2015 | 10:07 PM
  #43
OZZYAMG's Avatar
03 W211 E55
Thanks in advance
Hi
All I need to do when reversing is select "VIDEO" and "AUX 1" from my head unit and the reverse camera displays on my factory screen.
Regards,
OZZYAMG
Old Jan 3, 2015 | 10:39 PM
  #44
You have ntg1?
I have the ntg2.5 that should automatically come on when put in reverse.
Hi
Regards,
OZZYAMG
Old Jan 3, 2015 | 10:52 PM
  #45
OZZYAMG's Avatar
03 W211 E55
Hi
Whilst not 100% certain I think I have the NTG1.
I am under the impression that NTG2.5 has an SD card slot on the front of the head unit and I do not have an SD card slot.
Regards,
OZZYAMG
Old Jan 3, 2015 | 11:22 PM
  #46
Yes your correct.
Hi
Regards,
OZZYAMG
Old Dec 7, 2016 | 05:12 AM
  #47
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
w211 350 wagon where are you in VA? I'm in northern VA.
I purchased a coding box to unlock the feature of the NTG2.5 along with VIM. If you are close we can use it on your car to unlock your camera feature. Note that it will unlock but not give you the VIM since that has to be constantly connected to the headunit. But if you are looking for the back up camera feature this would do it for ya.
-Nigel
Old Dec 7, 2016 | 08:02 AM
  #48
VIM
Originally Posted by NewShockerGuy
Thanks Nigel, I'm stafford but I had it coded so all as working. As for VIM I bought software online that I put on an sd card and was able to unlock VIM.
THANK YOU FOR OFFERING w211 350 wagon where are you in VA? I'm in northern VA.
-Nigel
Old Dec 8, 2016 | 01:21 AM
  #49
Excellent! No problem. It just feels wasteful to have this and have only done my car...lol Anyone that is close that wants to have the camera option opened up I'd definitely help. I also picked up a DAS/Xentry system so that makes it even better to unlock stuff. I've done the rear flashing brakes, fuel remaining..etc.
I should have my camera installed by this weekend.
One question for you, where did you mount the camera? I as going to mount it to the right of the right license plate light since on the left is the trunk lock, but now I am thinking I might want the camera more towards the driver side. I can't get it dead center unfortunately because of the trunk release handle dead smack in the middle but I'm not really sure if 8" either way is going to make or break the view of a 150' degree viewing angle..lol
-Nigel
Old Dec 26, 2016 | 12:47 PM
  #50
Hey sorry took so long to respond Nigel, but I used one of those that replace the license plate light. I'm sure you installed it by now and don't think getting it centered matters.i tried the rear flashing lights and could never get them to work ...
-Nigel
