Is Eurocharged's remote cable tune like a dyno tune?
From my understanding, they send you a cable and then you download your ECU file and send it to them? Do they remote tune it as if it's on a dyno with air/fuel etc.?
I have read people are picking up 40HP/50TQ to the wheels from just a TUNE ONLY!
Any help? Thank you!
believe th remote cable is for your laptop to connect to the OBD port to your car. They "take over" your laptop and download the tune to your car. Make sure you have a charger to charger your battery. Dont want it to cause problems in the middle of the download to the ecu.
So it just an 'off the shelf tune' or considered like a dyno tune because they have the exact information from your ECU?
I am curious because I hear you don't gain as much from a box tune/off the shelf as you do from a true dyno tune...but this sounds like they are getting all the information they need to pinpoint tuning from the ECU.
Am I missing something?
1000Hp Diesel Trucks, 2019 E63s
And I think EC charges only like $35 to re-tune (e.g. dyno tune the ECU after running it with the box tune)...correct? Once you buy the initial tune from them ...
You really can't beat Jerry and EC. They seem to be Kleemann and Renntech caliber as far as rep goes and their customer service is remarkable while prices are VERY reasonable considering other options (Kleemann & RT).
Do you guys think that EC's box tune and ultimately, their dyno tune is safe?
I don't want to risk is blowing up my motor because of starvation, timing, knock etc!
(For what it's worth, I do not plan to upgrade the crank pulley or add any other mods other than a HE and Bosch pump).
Yea, the last thing you should worry about is blowing up your motor with EC's tune.
And since you're not adding boost/power, you'll be more than fine with their dyno tune setup once you're done.
Also, you should just go to a reputable dyno shop, strap her down, get all your numbers, AFs etc. and then contact EC. Getting a box tune, then dyno, then sending to them seems like overkill, no?
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
If we can handle this below the 55 isn't a problem.
EC box tune safe? Yes, i feel it bit "too safe". I always get on the dyno everytimes they come to the bay. No, it's not a dyno tune until you put it on a dyno to tune lol :d
You can easily disconnect the radiator fan when flashing the ecu to help with the battery drain issue. It's just one big connector near the upper left part of the fan (as you face it). Just don't forget to reconnect it when finished.
05 White Pano E55, Cadillac CTS-V
Yeah, you don't want to be trying to dial in fueling off narrowband o2 readings from a datalog. Well unless you have a wideband o2 sensor installed in the car and are using logs from that, but the Euroflash data logging software will be using the stock narrowband sensors.
The box tune will be rich which is safe for sure. My box tune was running in the 10s and after I got on the dyno and sent Jerry the dyno graph with air/fuel readout from the dyno (wideband o2 sensor) he made an adjustment and put the car at mid to upper 11s and a nice chunk of power was gained.
This place is a joke.
I thought the whole purpose of EC's datalog feature was to fine tune the box tune? Jerry had mentioned in the original thread something about using the factory O2 readings for this. Most of us do not have the ability to datalog with widebands.
It was a box tune for a supercharger pulley (along with headers and 80mm throttle body) after I switched to the supercharger pulley from a 180 crank pulley. So technically I lost power since I now run less boost so the car's overall power is less.
But the box tune had me run running all the way down to 10.0:1 air/fuel and had the car only making 446whp and then after the fuel adjustment it put the car up in the mid 470s on the next pull and then 1 minute later another pull was done with no changes and it went up to 479.9whp
On stock cars with just a box tune though they generally see over 30whp increase at minimum and running it on the dyno and adjusting the fuel after seeing a readout can pick up a little more.
If you do some searching on the internet about narrowband o2 sensors you can find how they have a small voltage range (0 to 1 vs 0-5 of a wideband) so there is abrupt changes in lambda readings with voltage change so it is hard to see a precise measurement using them.
SL55, ML500 & Acura TL
