Caliper upgrades ? Are there ?
Old Jul 5, 2013 | 10:18 PM
viren.89's Avatar
2004 E55 AMG
I was wondering like how Evosport offers 390mm rotors, are there upgrades for our calipers too ?
12 pistons ? or the one that comes as a 13k dollar option with ceramic rotors is the caliper same and just the rotors ceramic ?
Brembo GT kit is the same one we already have on our cars right ? other than the rotors ?
What aftermarket ceramic rotor options do we have ?
Pads I know Porterfields and Stoptech and Akebono
My pads have like more than 75% life but rotors aren't smooth anymore, I can feel the bump when I run the finger across. So I'd just be looking at changing Rotors alone but was wondering if Caliper upgrade is available ?
Off topic question - Cylinder heads and shorty headers , are one and the same thing ?
Old Jul 5, 2013 | 11:16 PM
Denroll's Avatar
'06 E55
I suppose you could swap the brakes from a Veyron or the Shinkansen bullet train in Japan (pro tip: those brakes are made by Akebono.). But for reals, swapping calipers on these cars is like doing an engine swap. It wont be cheap, it won't be easy, and it will make many go "why?" (E-V12 excluded).
Edit: Cylinder head and shorty headers: not the same thing. The heads are where the cams and valves are and is where the air goes in and exhaust comes out. Headers bolt up to the heads where the exhaust comes out. They are tubes, unless we are talking about the stock headers, in which case it's like a metal kazoo.
Old Jul 6, 2013 | 12:23 AM
cm60k's Avatar
Generally; 55sK Rotors with 8-pot with 4 pieces of pads in each calipers are heavy, compared to the newer "2007 C/E/CLS/SL63s"
which they has 6-pot with 2 pieces of pads each calipers & lighter Rotors, with definitely saves some weight,
which i believe its worth it.....
ZAYED,,
Old Jul 6, 2013 | 05:57 AM
viren.89's Avatar
2004 E55 AMG
^^ wouldn't 8 piston better than 6 piston ? apart from the weight savings 8 piston would have more stopping power?
Old Jul 6, 2013 | 05:58 AM
viren.89's Avatar
2004 E55 AMG
From Veyron ? lol so that means there is no middle ground? like a 12 piston caliper
Old Jul 6, 2013 | 06:41 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Your calipers are overkill as they are, if you were a competitive road racer you may observe flex in the abutment or the caliper housing itself but should not be concerned with it in the slightest for your car.
Old Jul 6, 2013 | 06:55 AM
viren.89's Avatar
2004 E55 AMG
What exactly does the steel brake lines do ?
I would get the big rotors but for them to work on my car I'd need new 19 inch wheels
Old Jul 6, 2013 | 07:02 AM
The steel brake lines don't expand when you press the brake pedal. This transfers ore of the pressure that you're exerting on the pedal to the caliper piston itself instead of letting the hose bulge outward. The factory hose doesn't expand much,so don't expect a huge difference.this was much more of a problem on older cars,newer stuff like this already comes with phenomenal brakes.
Old Jul 6, 2013 | 07:04 AM
viren.89's Avatar
2004 E55 AMG
Just to confirm, we have 6 piston or 8 piston as stock ?
Old Jul 6, 2013 | 07:46 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Google Rotora
Old Jul 6, 2013 | 07:47 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
The stock AMG/Brembo 8 piston calipers and rotors are over kill, as far as an up grade there are a few, very few. The most popular is-was the EvoSport light weight floating rotors, and there are 4 or five brake pad choices. There is a big brake kit by Brembo but at $3500.00 it is hard to justify.
The newer brakes are lighter but that is a result of cost cutting the MY 07 on cars cost $5k less to build. A big chunk of that was the SBC being removed, and a move to cheaper calipers. I know the SBC gets a lot of bad press but I really like it, the more you understand about it the greater your appreciation will be. End of the day I am sure a guy could throw $6 to $10 K at the brakes and get some improvement, I think the largest possibility for improvement would be a lighter ceramic rotor.
Take a look at the graph in this Road & Track test, pay attention to the stopping section.
For a big heavy car the distance is shorter than many lighter cars of the day 2003.
http://www.roadandtrack.com/car-revi...he-0-100-0-mph
SBC info,
http://www.mercedestechstore.com/pdf...%209-30-02.pdf
Old Jul 6, 2013 | 07:59 AM
marc.l's Avatar
2003 E55 estate
I run brabus/Alcon 12 piston fronts and 6 piston rear with 380mm front and 360mm rear with two piece disks . The braking power is night and day difference to standard .
I found with the originals after one lap at a track day the originals would be glowing red hot and fading .
Old Jul 6, 2013 | 08:05 AM
marc.l's Avatar
2003 E55 estate
Pictures are on flickr , under the user name allcars91
http://m.flickr.com/#/photos/97877163@N06/
Old Jul 6, 2013 | 08:19 AM
Forrest Gump 9's Avatar
shrimp boat
Damn, I was gonna suggest S65 calipers and call it a day.
Old Jul 6, 2013 | 08:52 AM
MindBend's Avatar
'05 E55
P030 brakes are larger 2-piece rotors, more pistons. With the right pads and fluid, if they fade, not much left.
Old Jul 6, 2013 | 08:59 AM
Definitely a worthwhile upgrade for your track use, but for this young man and his 100% street driven, nearly stock car the calipers are total overkill already. The 2 piece 390mm rotors I put on my car from Evosport made a nice improvement on a car that already stopped great,but he said he's not interested in that because then he has to change wheels. Just put some nice pads and new stock size rotors on it and you're done thinking about it.
Old Jul 6, 2013 | 09:39 AM
MindBend's Avatar
'05 E55
No one ever talks about fluid--change it now, change it often. The fluid is an integral part of your braking success and is hygroscopic--absorbs water.
MB recommended service intervals even recommend it at 20K/2 YRS, I think.
Old Jul 6, 2013 | 09:50 AM
E55Dimon's Avatar
E63S
I literally burst out laughing at the train. LOL!
No need to swap the calipers, just go evosport/akebono and don't look back.
Old Jul 6, 2013 | 06:46 PM
viren.89's Avatar
2004 E55 AMG
Doesn't SBC take the feel and feedback away from the Brake Pedal, so regardless of how large the calipers are it'll stop better but there will be no feedback ?
Old Jul 6, 2013 | 06:52 PM
viren.89's Avatar
2004 E55 AMG
I have 15 mm spacers all around. If I put biggers spacers could I fit evosport or HAS HAVE TO BE 19's ? ??
Other than evosport there ain't any other company which sells better than OEM rotors ?
oh and I do have aftermarket wheels on but they are still 18's lol
Old Jul 6, 2013 | 07:04 PM
Denroll's Avatar
'06 E55
You have wheel or caliper spacers? The evosport rotors require the 19" wheel because you will add caliper spacers.
Old Jul 6, 2013 | 08:10 PM
viren.89's Avatar
2004 E55 AMG
I have wheel spacers on right now but I understand what you are saying and based on that 19 inch is a must.
No aftermarket option that is better than OEM but in 18 size ? well E63 ones would fit E55 but there ain't any weight savings on those I think
Old Jul 6, 2013 | 09:06 PM
viren.89's Avatar
2004 E55 AMG
SBC info,
I went through all 36 pages and it is a very complicated unit. lol I think the bad press it gets is due to it not giving any pedal feedback (it's a luxury car and that was their purpose I think) and the noise that comes on repumping of the unit.
Old Jul 7, 2013 | 10:37 AM
Bramage's Avatar
F-250
Old Jul 7, 2013 | 11:08 AM
There's a few different rotors you an get as an upgrade in the stock size including the 2piece Evosport ones. I don't know if Evosport is still in business but just do a better rotor in the stock size and your 18s will fit just fine. The stock rotor are already huge!
