What's the verdict on the smaller SC pulley?
Rating: Thread Rating: 3 votes, 5.00 average.
Old Oct 2, 2013 | 10:39 AM
  #126
Joncl's Avatar
E55
Yes split the cooling and try to cool down the car before doing your dyno
Old Oct 2, 2013 | 10:42 AM
  #127
SavMan's Avatar
2004 E55K AMG Wagon
Originally Posted by C32owner
Oh ok, I was told it did not start to pull timing at this temp.. Do you know at what temp it starts to pull timing ? I was also suggested to split the cooling, maybe I should do this before exhaust then, its a relatively inexpensive mod.
+35 deg c IAT timing retarded 3.5 deg
+45 deg c IAT timing retarded 6.3 deg
+65 deg c IAT timing retarded 9.6 deg
So you hit all 3
Try a 3rd gear pull on the road even if you can't top out look for how quickly the IAT's recover when you lift off you want them to return within 3 secs.
Old Oct 2, 2013 | 10:45 AM
  #128
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
So you hit all 3
3 seconds, shucks, don't think I seen that, although never focused on it before. Thanks for the valuable information. Will definitely go check it out!
Old Oct 2, 2013 | 10:46 AM
  #129
SavMan's Avatar
2004 E55K AMG Wagon
WOW, ok, that would explain a lot then! Seems the split cooling needs to be done asap then!
The main one to worry about is 65C / 150F its tough (depending on where you live in the world) to get below the next step of 45C / 113F and never heard of anyone get below 35C / 95F IAT
Old Oct 2, 2013 | 10:57 AM
  #130
SavMan's Avatar
2004 E55K AMG Wagon
Just to clarify the 3 secs is from when they start to fall not from the moment you lift off, if you are logging it will be easier as you will see the start of the drop off
Old Oct 2, 2013 | 11:00 AM
  #131
E55AMGGG04's Avatar
04 w211 E55
Yes that right, its stock.. Beeeeg problem is that is done at an elevation of 5000' . Also that number is uncorrected at all.. I wanted a pure number what the wheels are putting straight on the ground, as that is what we feel and experience at the end of the day, not corrected to sea level, as I don't live at that altitude anymore, unfortunately Really disheartening, to see this car stock at this altitude put down same power as what I got out of my C32 at sea level.. lol
Oh okay I gotcha! I'm sure butt Dyno must've felt good though after the installs. That's incredible what kind of effect elevation had man! At sea level it should be fine.
Old Oct 2, 2013 | 11:04 AM
  #132
C32owner's Avatar
Ok thanks, so when I lift off there will be a slight delay, once IAT's start to drop then within 3 secs they should be back to normal intake temps
Old Oct 2, 2013 | 11:09 AM
  #133
C32owner's Avatar
Must be honest, wasn't day and night. Felt a little stronger down low with the extra torque... Now this same setup on the C32 was a massive difference! The butt dyno was very happy there
Old Oct 2, 2013 | 11:36 AM
  #134
Denroll's Avatar
'06 E55
It sucks paying money for cooling mods because you aren't "gaining" power, just "recovering" what is already there. I wanted to swim against the current and save that stuff for last and quickly learned it wouldn't work.
I bigger heat exchanger isn't too expensive and worth it. I am running a Meziere pump and that thing is solid. Also using the BMW power steering fluid tank as my under-hood reservoir. Best cooling is with water/meth, though. A pain in the urethra to install, but not very expensive for the hardware.
Before the meth, I would still see 180 degrees on a long run with the heat exchanger, meziere, and split cooling. Recovery is nice and quick, but the stock intercooler core just sucks for big boost cooling.
Old Oct 2, 2013 | 11:41 AM
  #135
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Judging by the mods in your sig, I assume you're still on the stock I/C pump and H/E? If so, I doubt you'll cure your heat issues just from splitting the cooling.
Old Oct 2, 2013 | 12:07 PM
  #136
E55AMGGG04's Avatar
04 w211 E55
I'm pretty surprised. I had a eurocharged tune before I installed the s/c pulley, tcu tune, heat exchanger and I felt the gains without a doubt. I also changed my spark plugs. I wish I could've done a before and after Dyno but there was too many cars to get it on there.
Being that you were stock and doing the tune/pulley combo and not feeling the gain does sound very disappointing. I wish we were close enough to do a side by side good ol 3 honk comparo to see how the car is running :/
Old Oct 2, 2013 | 12:45 PM
  #137
Bramage's Avatar
F-250
below 95F??
No sweat.. of course this is only going up to about 130mph....
Old Oct 2, 2013 | 12:54 PM
  #138
venomsE55's Avatar
E55 AMG
What are you guys using to read and log your intake temps
Old Oct 2, 2013 | 01:09 PM
  #139
Denroll's Avatar
'06 E55
Bramage and I both have the Zeitronix suite with a DashDAQ display. Not cheap, but the best way to log just about everything with these cars.
Old Oct 2, 2013 | 01:44 PM
  #140
Bramage's Avatar
F-250
Intake temps are easy to get, its the other end that's a little uncomfortable...
Old Oct 2, 2013 | 02:40 PM
  #141
E55AMGGG04's Avatar
04 w211 E55
How's the beast running now with the new cooling mods!?
Edit: I just ordered a PLX KIWI obd reader for the car, $110 shipped and I downloaded an app to pair it for logging.
Old Oct 2, 2013 | 03:25 PM
  #142
SavMan's Avatar
2004 E55K AMG Wagon
Originally Posted by Bramage
below 95F??
Meth ?
Old Oct 2, 2013 | 03:32 PM
  #143
Denroll's Avatar
'06 E55
^Yep. That's the screenshot that sold me on getting a similar setup.
Old Oct 2, 2013 | 05:31 PM
  #144
SavMan's Avatar
2004 E55K AMG Wagon
Damn... I have a kit that's sat in my garage for 4 months, pestered RBJ for weeks asking him stupid questions and still not got around to fitting it. Need to get off my backside and fit the damn thing for some of those sub 100F IAT's
Old Oct 2, 2013 | 07:19 PM
  #145
Denroll's Avatar
'06 E55
I did a DIY install thread with pics on the other site. Just realized I never posted it here.
Aside from the nozzle install, it's not that bad if you have a friend helping.
Old Oct 2, 2013 | 07:48 PM
  #146
SavMan's Avatar
2004 E55K AMG Wagon
Thanks just read it, just need to find myself a friend now
Old Oct 3, 2013 | 02:25 AM
  #147
C32owner's Avatar
So you hit all 3
Alrighty then, tried this last night on the road, and results are as follows.
Normal cruising highway speeds of 70mph the IAT was stable at 36'C (97'F)
Selected 3rd gear pull to 6000RPM and IAT rose to 63'C (145'F) let off the pedal and after about 2-3secs the temp started to drop, at which point started timing and took about 18sec to drop to 51'C (124'F) To get back to where we started at 36'C (97'F) took probably around 1 min..
Does it sound like cooling issues, or pretty normal for a stock cooling system?
Old Oct 3, 2013 | 11:48 AM
  #148
chawkins2001's Avatar
2006 E55 AMG
Hoe gaan dit boetie Is jy in Jo'burg of Kaapstad? Dit lyk soos Joburg.... Anyway, that gain is definitly off and if you are hitting temps of 180* F, that explains alot for the minimal mods you have. Have you split your cooling yet, and do you have air fuel and timing data? What does your dyno graph look like?
Old Oct 3, 2013 | 12:19 PM
  #149
blackbenzz's Avatar
haters crazy
I like the dashdaq but the sample rate from the car is not quite where I'd like it to be. Are you getting your rpm through obd2 or elsewhere? Also with the meth what size nozzle are you running and where is it placed? 50/50? Thanks. Those are crazy good IAT's. I have to resort to stuffing it with ice lol
Old Oct 3, 2013 | 12:38 PM
  #150
uberwag's Avatar
2017 SQ5 / 2012 Ferrari FF
I have a 176 crank with smaller SC pulley, pretty sure there are some running 180 and above.
You will need lots of cooling and likely injectors to match though.
I am running a 180mm crank and EC Supercharger pulley. Rather, I was. In the process of going back to a stock SC pulley per Jerry's suggestion, with a re-tune and trunk tank. Made good numbers when first installed (525rwhp/615rwtq) but has gone down since as we've upgraded the tune to account for split cooling and removing the cat's. Interested to see where it shakes out after the re-tune on Monday/Tuesday by Jerry in Houston.
They've done the same with other vehicles that have had a big crank pulley and smaller SC pulley, where they go back to a stock SC pulley and gain on the dyno. No, I don't know how that works either, but I trust Jerry when he says it. For anyone that is combining a big crank and small SC pulley, talk with Jerry first.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
