Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class AMG: How to Replace Brake pads/calipers/rotors
Step by step instructions for do-it-yourself repairs
Common replacement and maintenance parts - all in one thread
#351
Hi, I couldn't find any information about it, the question is who can confirm it for sure. The M113K engine is available on many models, but depending on the model, the difference on the crankcase side, which also concerns the oil pump and the lower part, is the part on the block side interchangeable from G (has code on block 113993) class to E / CLS (coded 113990 / 113987) if move the crankcase and oilpump aggregates and it would work fine?
...can I take the 113993 block with internals and fit it on E / CLS.
#352
Toadster (01-24-2024)
#353
Thanks, luckily that's already cleared up. Yes, it's the same on the block side, the difference comes from the oil pump, crankcase and other aggregates. Things that are already exchangeable according to the model. I have also found a suitable and correct block.
#354
good deal for Black Friday!
Chemical Guys HOL126 14-Piece Arsenal Builder Car Wash Kit with Foam Gun,
