55k engine - need help with supercharger drain screw!!!
Was changing the supercharger oil yesterday and dont even ask how the mechanic managed it, but despite all the tissues under there he still managed to drop the little screw into the bowels on the engine bay.
Does anyone know if a replacement fill screw is available and what part number i should be asking for?
Or is there an alternative coz the cars been stranded since last night.
Thanks.
Thanks.
You wouldnt happen to remember what size the replacement was would you?
your best bet is if you dont want to take the S/C out which i dont blame you, is go on the sale threads see who already has them pulled out and is selling them and ask them to simply unscrew the bolt and measure it.. there is plenty of superchargers for sale out there, hell even on ebay i would email the seller and ask to see if he can do a quick favor, thus saving you all that headache
You could go to Home Depot and buy M6, M8, M10 and M12.......ect..... metric bolts and see which one fits, then cut to size put a slit in the top so screw driver will fit in and hope for the best....
M8 =- nearly touches the sides but wont catch
M10 = Too big
Any special tools needed?
As a matter of fact my guess is that the screw may have actually ended up underneath the supercharger by now anyway.
PLATINUM SPONSOR
I have my SC off the car, let me get a thread gauge and check it for you tonight. It has to metric, as the SC is made in Japan. It may be off size , like M7.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
But it wont be an M7, iv tried that already, lol.
An M8 just seems to miss the threads and an M10 is a little too big.
Its definitely something odd sized, like an M9 quite possibly?
PLATINUM SPONSOR
It measures to be a 3/8" allenscrew and hard to say what thread pitch but on my gauge 20 looks about right.
__________________
www.ultimatepd.com
www.ultimatepd.com
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Nutty..
I was thinking that the DIY thread suggested a sheet/towel or something to keep it nearby in case this happened....
But unfortunately all the tissue was directly underneath the hole where the screw goes in as thats where your likely to drop it.
In this case though, as the mechanic was pulling the screw back out it actually hit the back of the supercharger pulley and came off the allen key. In reality no one saw it coming off at a point this far out so no one put any tissues under there. Also, if you use magnetic tools you wont have this problem, in this case they are worth the extra bit of money.
YOU SIR, are an absolute SUPERSTAR
Now im gona try and find one of this dimension or see if a local engineering firm can make one to this size. Thread size will be a trial an error i guess.
MBworld Guru
