3K Stall Torque Convertors - New Shipment
But yeah, most transmissions also let the lock go between shifts as well.
I emailed John at IPT earlier today, hopefully he can provide some insight on the E55 AMG lock up function and its programming.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Also using the factory torque rating of 516 and an observed stall speed of 3000rpm would give these particular converters a K-factor of 132.0473$373838$48383):$:&;$
Round it to 132 for simplicity sake.
www.ultimatepd.com
www.ultimatepd.com
I'll gladly eat crow if I'm wrong but I'd wager a case of beer 800 foot lbs is the rating for the converter and not specifically the lock up function since TCU's do not engage the lock during shifts or WOT.
www.ultimatepd.com
Product Description
3000 stall converter for street or strip
11" diameter vs stock 12"
10 lbs lighter than stock to reduce rotating mass
triple lock up clutch
high performance pump and bearings
all new and no core charges!
Price is 950 plus shipping in the continental US
Members who have this unit please post your reviews.
