SOS Tele Aid Inoperative
Old Jul 20, 2013 | 06:59 PM
gtr886's Avatar
E63 W211 08, C32 W203 02
Exclamation SOS Tele Aid Inoperative
I have a 2008 E63 w211.
The "SOS tele aid inoperative" came on after I used a odb2 reader to clear off a check engine light. After I start the car, the " SOS tele aid inoperative" message came on.
I called SOS and with wrench button, both work just fine. I have the subscription on this car too. the operation was able to located my car as well. what do you think the problem is?
Should I go to the deal and have it disable? or is it something else?
Thanks in advance.
Old Jul 20, 2013 | 08:11 PM
211.076's Avatar
2003 E55
Do you have Navigation? If so, is it functioning properly?
The most common failures within the Tele-Aid are the main antenna (roof) or you could have some corrosion in the splitter. Another fairly common problem would be the tele-aid spare antenna. Best to go to the dealer and have the codes properly diagnosed.
