Push start button stopped working !
Old Jul 21, 2013 | 05:52 PM
AMG E Power's Avatar
E55 amg
Any ideas what could be wrong guys ? I can still keep the key Fob in my pocket and open the doors and unlocked them through the handles but, no luck with push start
Old Jul 21, 2013 | 06:10 PM
Denroll's Avatar
'06 E55
Spend 3 grand and get one from an SLR.
Is it not even turning on accessories? Key not recognized message in dash?
Old Jul 21, 2013 | 06:20 PM
E55 amg
What a great idea !
In all Seriousness no Accessory lights, nothing. I open the door via keyless entry And it's beeping annoying saying don't forget your key and that's it I push the button nothing.
Old Jul 21, 2013 | 06:29 PM
Denroll's Avatar
'06 E55
Hmm, does sound like the switch/button.
Oh, and one member here did pay to get the SLR shifter/button.
Old Jul 21, 2013 | 08:44 PM
211.076's Avatar
2003 E55
Probably not. There are no electronics in the button. It is simply two prongs that extend to release two locks inside the EIS to start the car. The only way it would be a switch is if somehow the prongs were damaged and not extending fully. More than likely it's a problem in the EIS. Although its difficult to diagnose a vehicle without actually seeing it/the problem
Old Jul 21, 2013 | 09:37 PM
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
Try changing the batteries in your key.
Old Jul 21, 2013 | 09:38 PM
groove66's Avatar
2005 e55
I have actually seen the wires broken from being shifted back and forth for a bunch a years. you would have to take off the shift boot and look down the shifter slot with a flash light to see..
Old Jul 21, 2013 | 10:22 PM
E55 amg
^^ are u talking about the to little prongs in the shifter knob ?
Old Jul 21, 2013 | 10:47 PM
211.076's Avatar
2003 E55
Holy cow. Just had a brain fart back there. Didn't realize the start button was on the shifter. I would agree with trying the batteries in the key first. Do you have a red light visible on your key when you try to lock/unlock the car. Could potentially be the shift knob as well.
Old Jul 22, 2013 | 04:33 AM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Can I buy the button separatly or do I have to buy a complete used shifter?
Old Jul 22, 2013 | 10:08 AM
211.076's Avatar
2003 E55
You can get just the shift knob (which houses the start/stop button) separate from the rest of the shifter. The only thing I would be concerned with is if the problem may lie in the shifter.
Old Jul 22, 2013 | 10:49 AM
BaDiNfLuEnCe55's Avatar
2004 m3, 2005 e55
Having the same issue also. My button was stuck so i ended up changing my knob.. Now it wont work at all, door handle work fine and so does trunk i believe
Old Jul 22, 2013 | 11:26 AM
E55 amg
my button doesnt seem to be stuck. I press it and nothing happens at all, no key not recognized on the LCD. keyless entry locks and unlocks the doors and opens the trunk. I have no Idea. guess I have to take to the steeler or and indy... F*ck !
Old Jul 22, 2013 | 11:38 AM
Tremek's Avatar
'17 GLS 63 AMG, '08 S65 AMG
I think I have read somewhere on here that there two batteries in the key fob? Could one (which allows for keyless entry buttons) still be charged, but the one responsible for KeylessGo be dead? Seems like a cheap thing to fix/change before taking it to a shop.
Old Jul 22, 2013 | 01:17 PM
E55 amg
Not the batteries like I figured. I gave it a shot and got new batteries and no luck
Old Jul 22, 2013 | 01:36 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Try to see if your brake lights work every time you push the pedal. Seen on the forums that the brake light switch on the brake pedal sometimes will act up and cause a no start. With the car started press the brake pedal so the light are on then shut off the car without moving your foot, now try to restart using the shifter button. worth a try!
Old Jul 22, 2013 | 02:08 PM
biggking's Avatar
So you can not get the start/stop button separate?
Old Jul 22, 2013 | 02:28 PM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
I'm having the same issue, my push button does not work. Just recently after 10-15min of driving or leaving the car on my command unit, A/C & Heated seats, and parking sensors turn off, and the A/C goes from whatever I had it on to half way. I changed the small AUX batter under the cabin filter and my trunk battery isn't even a year old. I checked the voltage on both battery's as well. Going to test another shifter and see if it works. If not I'm thinking a module is bad or something. Has anyone had/have these issues?
Old Jul 22, 2013 | 02:31 PM
rxsamg's Avatar
2006 E55, 1997 Mustang Cobra Conv
Unlikely the braking wiring as i beleve he indicated no accessory position/lights either. So not even getting to the point of where brakes matter in the process.
Old Jul 22, 2013 | 02:36 PM
E55 amg
this really sucks a$$ ! I hate using my key fob to start the car. Hopefully someone will find a EZ fix before I get raped at the steeler.
either way I will find time this week to take it cuz I love my push start
will report back.
Old Jul 22, 2013 | 03:33 PM
EGray@Germain's Avatar
2020 AMG C63s
will report back.
Where you located? I'll speak with my MB cert tech here at the dealership and get back to you have he says.
Thanks,
Eric
Old Jul 22, 2013 | 03:40 PM
E55 amg
^^^ thanks I would greatly appreciate that. IM in FL
Old Jul 22, 2013 | 03:42 PM
baldmike73's Avatar
be careful when taking shifter off - very easy to break those prongs - i had to replace the ****er gate - wires were still intact - was only a couple hundred dollar fix - better thing is to replace the shifter boot/button with newer 211 style one - say from an E63 -
Old Jul 22, 2013 | 03:45 PM
E55 amg
ya I have seen the two little prongs in pics and I think maybe they are bad ?
Old Jul 22, 2013 | 04:18 PM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
same **** happened to me it was the brake light switch witch is ten buck to fix or it could be the battery
