Got the CTS-V...comparison to my 2004 E55
:r olf:
:rol f:That is freakin great!
It made 594whp 570wtq yesterday before the tune was touched and this was in very hot and also fairly humid weather. The car was making 15psi on the dyno and running 93 octane. He adjusted everything about the tune and also adjusted the bypass valve right at the end before getting off the dyno and finalizing with some street tuning. On the street it saw another 1.5psi of boost (we actually saw 16.8 in one log) so is most likely making another 20whp on the street than what was saw on the dyno. The final numbers were 619whp 619wtq on 93 octane with the car blazing hot, no cool down, no ice tank reservoir for added capacity which I am going to be buying. It also seems to have a intake air temp problem which is possibly a bubble in the system somewhere that I need to look in to, so these numbers were with IATs going to around 160-170. Even on the street cruising we were seeing temps in the supercharger about 20-25 degrees hotter than they should be.
The weather at time of dyno was 92 degrees and 54% humidity with a DA of 2635, so not to bad in my mind
The tuner Jeremy Formato of Fasterproms is legit and is one of the best in the LS engine world from what I hear. Not only did he make nice peak gaines with the retune but he made substantial low and midrange gaines. It will be interesting to see what the car will do now during the winter and also with the rising intake temp problem fixed.
[IMG]
[/IMG]
Good to know worst case scenario with high intake temps and hot weather you are making ~620-640whp and just going up with better weather. Now I am thinking about porting the supercharger for another 40whp and then having a couple other little things done for better intake temps. Just ordered a 1.7 gallon underhood coolant tank as well (Norcal SS tank).
He used to port them less and saw 30-40 and started porting more and saw the increases to the 40-50 range.
A quote from Jeremy
The 3rd had a 2.55 pulley, Corsas, ported snout, and tune from a very well known vendor. Baselined at 520RWHP 490RWTQ. We reported the snout took about a 1.5lbs of alum out of it, ported the blower another -4lbs er so, put 850cc inj in there and retuned it and it redynoed at 589RWHP and about 570RWTQ with no headers and stk cats all in 90deg F florida weather.
Side Note:
Here are a few pics of my car. I just realized that I have been posting but never displayed my vehicle.
A quote from Jeremy
I am bringing mine in for upper pulley 160 stat and tune early next week and then I will go from there...I have corsa exhaust and air raid cold air. For now I want to stay away from headers and lower pulley and get as much as I can out of it. Anything else that you guys (hotsoss, URB) recommend? If the porting things are easily done then maybe I will do that but it doesn't sound easy. Bigger injectors? I am sure that I don't need them now but I will in the future!
I know you guys would think to just ask this on the caddy forum but to be honest...this forum is just much better. I don't know what it is about that forum.
Whether I have a Caddy or a benz...I will still be on this forum!
Their stage 2 package consists of:
1. 2.5 Upper Pulley (You can choose a 2.4 if you wish)
2. Idler Pulley
3. ID850 injectors (Definitely don't skip out on the injectors because you will likely be at close to maxed out with a 2.5 + you want room to grow with mods and peace of mind knowing that your engine is not starving for fuel up top)
4. 160 T-stat
5. NGK Plugs
6. Custom dyno tune for the ECU & TCU on Mustang dyno (They also dial in your tune on the street with you driving)
In addition to their Stage 2 package and what PetroC63 has:
7. Airaid - You got this already and corsa cat back.
8. Ported LSA Throttle body and Snout package (If you want a little more bang for your buck, upgrade to their ported LS7 or buy a Tony Mamo ported LS7 throttle body. I can PM his info and Tune Time number is you want it.)
You will also need to procure a Heat Exchanger. I would contact Ben (WeaponX) from the Caddy forums on some great deals. I purchased a center mounted heat exchanger during his last group by in April/May. I have yet to have it installed, but I know I will need it once I get started.
If you have no plan of doing a crank pulley I would go for a 2.4 or 2.35 upper pulley, with your intake/exhaust and that the car will fly still with 575whp range power on a good tune of course. Also get a solid isolator to replace the factory unit that wears on the shaft, do it now while the snout is off to change the pulley, they are cheap anyway.
You need to get some injectors though with that setup, stock which are like 588cc are good for about 530whp. There are guys with a 2.55 upper pulley with intake/exhaust (not headers) on stock injectors but are most likely right on the border and the setup I just mentioned is right on the maxed out range on the upgraded 630cc injectors. I would go straight to a 850cc size to have plenty of headroom especially if you think there is the slightest chance you would change the crank pulley or do ported stuff down the road. They are more pricey though, so I guess decide how much money you want to spend and then determine the power level you want to be at and go from there.
You could be happy with a 2.5 upper and 630cc injector setup. My car was previously tuned with headers/exhaust, 2.5 upper, intake on 630cc maxed injectors to 563whp 566wtq, but you can get there without headers, they just had to stop there due to the injectors being maxed but guys without headers and that same setup have made basically the same power. The car trapped 124 at that power level on street tires.
Here is another little video a friend took of the exhaust a week or so ago.
That is true, but Tune Time might still be running a special where they will port the snout and stock throttle body for like $425.00. Basically they are throwing in the port job on the throttle body for free.
Note: This deal might be over, but it is worth looking into.
I 100% agree.
They use an all wheel drive Mustang dyno that reads low. I only put down 483rwhp & 504rwtq after my mods but I ran 10.8 @ 127 at Atco in -600 DA.
http://www.youtube.com/watch?v=7huUY...zZI35sCCrxH9SA
