What is your oil temp? E63 owners or those who have E63/CLS63 Gauge Cluster in E55.
My oil cooler fan on my 2005 E55. is making some funny noise. Im seeing 97-98 degrees celcius during normal driving. Is that normal?
Does anyone know if it will light up red if you get it too hot (hard driving) Or will it just keep displaying higher temps.
Just want to know if my temps are OK.
Oil temp should be 180 *F or ~80*C....If you are seeing 212*+ F that is a tad too high (unless you are racing, but even then you should keep it below 200* F)...
Also the Oil temperature display on the cluster will actually flash until the oil reaches 80* C... The owners manual even states to keep the revs below something like 4500 RPM and not be too aggressive until the oil temp is above 80...
Clk 63 99-105 degrees C
Stop and go traffic in the heat of the day , max 105 on my E63
Clk runs closer 102 normal, maybe smaller cooler but have seen 107 sometimes
80 degrees is when the flashing stops and the fun begins.
Have you ever noticed how hot the engine valve covers are after just normal driving, you cannot hold your hand on them for a split second. Hours after shut down the engine still retains a lot of heat. This is one of the reasons we run synthetic oil and lots of it (9 quarts)
When you say 100% anti freeze do you mean pure antifreeze with no additional added water, if so this is wrong. Pure antifreeze will actually freeze before the proper mixture of antifreeze and water will in the same application. 50/50 is good for top ups.
Now the oil temp, I notice you are in sport mode 5th gear 55 mph, revs unknown,
This means the trans starts in first gear and is a little more aggressive with the engine/trans rev/shifting. Drive the car in C and compare the temps I think you will see a difference, most I have seen is 107-108 on the wifes' CLK63 Cab the E63 never got that hot and for that I do not know why ha ha. Check the coolers for debris just in case it's dirty . There is a check to see if the cooler fan pass side is running as it will spin up when you start the car, get someone to start the car an listen pass/side front for fan spool up then shut down.
