Just did brake pads. Still have the wear warning
I went into the service menu but didn't see anything listed for brakes, so I tried confirming a full service. Still have the message. Grrr.NOW, here's the interesting part. When I went to the driver's side rear after doing both fronts, there wasn't a wear sensor. I thought maybe only the fronts had them. Then I did the passenger rear and there was a sensor. Should I assume my sensor somehow fell out? I mean there's not even a bolt in the caliper where the passenger side one is. I assume that's why I still have the brake wear warning? The pads were LOW, so I'm glad I have Akebonos all the way around now, but lord do I hate clearing the messages every time I start my car. So is there a sensor missing? If so I'll order one up tomorrow.
Thanks guys.
If the sensor either front or back has touched the rotor" in case of very low pad " then the sensor face is damaged and must be replaced, for a few bucks do both and make sure connection is clean when installing. Yes good pads usually come with the sensor.
Hmmm, My fronts DEFINTIELY have sensors on both driver's and passenger's side. It was the driver's rear that had no sensor, sensor bracket, hell I didn't even see a wire for the plug. Can anyone confirm? I need to know whether to order 3 or 4.
THANKS!
Thanks for helping me "put the brakes on" and breathe a little. I see what you're saying. The rears were MURDERED.
Can you spot the difference between the old one and the new Akebonos? LOL!
I did get a little overzealous removing the front passenger sensor and it pulled the rubber away from the inductor though. I'm not even mad now. Just hit RockAuto and I got all 3 sensors for 15 bux shipped. Talk about the cheapest parts I've ever seen for this car
Part of the reason for the sensor on the passenger rear (wear) is that when the wheel starts to spin then that brake is applied to send some power over to the other side, sort of a cheap posi ha ha , so in effect the passenger rear will wear more than the drivers side
Glad all is well now.
