Fixed Pulley Review and Findings...
What I noticed right away is that during cruising (off boost) driving, the IAT's are on the average 10 degrees higher than before when I was running Shardul's smaller SC pulley. Meaning if I was at 12 degrees above ambient, I'm now at 22 degrees above with the 77mm pulley. This is only during cruising but totally understandable being the blower is spinning all the time now so it will generate more heat.
In order to put things in better perspective, here's a list of my cooling mods:
-split system
-PLM heat exchanger
-Bosch 010 pump (constant circulation)
-small reservoir located outside the engine bay (behind grill)
I am however enjoying the absence of the clutch engagement, as I've always felt it robbed the car of it's luxury feel. Also feels noticeably peppier than it did with the smaller SC pulley.
Hoping others chime in with their thoughts and findings. Its a new mod so the more information we share the better it is for all of us.
I'm keeping a close eye on my gauges to prevent any potential harm.
https://mbworld.org/forums/w211-amg/...ge-thread.html
I agree with Toad on this one, even while cruising the 180 size spins the blower faster creating more heat than a 168 would. Remember even while cruising our pulley is engaged majority of the time.
If I were to run the 83mm fixed pulley (which is equivalent to my smaller clutched pulley) it would still create more heat off boost than the clutched one.
Both my clutched pulley's engaged at around -2lbs of vacuum (just prior to boost).
Running more even with the right temp will still shorten the SC life. Plus, I don't really think they will last 300K in stock form. My point is, few of us has the car more than 100K miles and how long the SC will last with this pulley.
As for you stating that our cars don't have a lot of torque off boost, I am not sure what your comparison is, but generally most would agree that a 5.5L v8 can generate a fair bit of torque....Add boost and you have the potential for monster truck levels (j/k)....
I really am not convinced the extra heat, or load for that matter, is worth it...
What I'm saying I have seen that's all.
I guess I'm comparing torque off boost like driving with a bad ic pump after the sc shuts off and the engine makes 200 lbs. give or take ofcourse.
A 5.4 liter v8 with 8.5:1 compression isn't going to be a beast off boost IMO
I just uploaded a revised file so I'm gonna go put some miles on it to log the differences.
A lot of you guys stayed away from a 180 crank pulley because of the heat it builds on the motor and some of you wouldnt get it because of the one in thousands of crank pulleys that broke or otherwise. Now you're slapping a fixed 77mm upper pulley(basically 180mm crank), without a tune? What the hell lol..
I'm still interested in to what the tune does for a fail safe...
The reason, well one of them, the pulley is clutched is to save the motor from its own temperature demons. It turns off the supercharger if your temperatures get too high, makes sense right?
So you've added a heat exchanger, good, that's going to make sure you recover faster and hold your IAT's down a bit longer(a couple seconds) when you're on the boost. A lot of you guys have already noticed, just having a heat exchanger in conjunction with a better pump, does not eliminate temperatures eventually reaching high levels(back to back pulls). You guys that are adding this fixed pulley need to find a more helpful modification to reduce cooling especially if you guys are daily driving your fixed pulleys. Killer Chiller, Methanol Injection and Split cooling would be your only options. Based on what I know of our cars I would safely say these are must needs now with these fixed pullies and high mileage motors.
